Lifting ground on Spectral amp
ack
May 6, 2010
6,774
1,198
580
Boston, MA
So, even if I plug both the Shunyata D6000 and the DPC-6 into the same 20amp circuit, via the two receptacles connected to that circuit, I'll still get the ground loop I've experienced?
I don't think that will be a problem, or if it is, it will be very subtle; but regardless, my suggestion is to start simple with one distributor on one circuit, plug in amps and preamp, test, then farm out. You have to first prove that you have no loop with proper star grounding. I think the problems will appear the moment you introduce the second line, and when you start moving components on it. Proper grounding has to be taken seriously.
CGabriel
618
92
265
WA, USA
www.shunyata.com
If that's the case I could plug the DPC-6 into the D6000 so that I've one single plug into one circuit.
By the way, I have been using a Synergistic Research Grounding Block which incorporates star ground for their product set along with other elements of my system. These include the DAC and preamp via spare inputs. I'll disengage this for testing.
All DENALI power conditioners have one or more ground lugs on the back on the unit. These are designed specifically to create a common ground connection between the conditioners. They can also be used to connect the chassis grounds of the components in the system.
stevebythebay
242
119
948
Well I brought in the D6000/T from my local dealer for a test drive at home. Within a few minutes I knew it was a worthy addition to my system. Just received mine along with the Sigma HC power cable. Given that I've got a setup that includes the Denali and DPC-6 for my digital devices, as well as a star grounding block from Ted Denny's Synergistic Research, all on separate circuits, I figured that any ground issues might be mitigated by reducing this number.
I've needed to lift ground on my two mono blocks from Spectral to keep the hum away using a couple of Ted's cheaters. After a quick email to Steven Plaskin on whether his experience with the grounding blocks included wiring this into his Triton. Seems he did so awhile back via some sort of Shunyata cable, and he's liked the result. I gave it a go last night, initially using one of Ted's base wires. Results were a bit less hum. So, I took the plunge and decoupled the high resolution wire I have been using to connect the grounding block into the wall and wrapped the end around the grounding post on the Denali. Result: absolutely no hum with my ear within a few centimeters of the midrange driver.
Now once I feel the HC power cord and Denali are fully broken in, I'll try plugging the DPC-6 into the Denali and remove the cheaters to see if I have any ground loop hum from the system. I'd expect not, but who knows.
ack
May 6, 2010
6,774
1,198
580
Boston, MA
You just tied the grounds, good.
marty
4,211
2,520
United States
There is leakage current to the chassis inside your electronics which causes ground currents/hum with no contributions at all from your electrical wiring. The solution to this is to use balanced interconnects. I see that your power amps have this. Are you able to connect them this way?
Amir's recommendation is the wisest of the lot (of some pretty screwball suggestions). I had a low level hum with my Spectral 400 amps and went with a balanced interconnect which solved the problem entirely.
stevebythebay
242
119
948
I'll consider doing so once Spectral releases their long delayed Reference interconnects and speaker cables.
stevebythebay
242
119
948
Are you suggesting that I ground the DPC-6 to one of the two ground posts on the Denali, rather than plug the DPC-6 into the Denali? If so, how would I do so?
CGabriel
618
92
265
WA, USA
www.shunyata.com
As long as you use a power cord that does not have the ground wire disconnected, it is already connected to the Denali ground system internally through the ground wire in the power cord that connects the DPC-6 to the D6000.
The Denali 6000/T has two CGS grounding terminals. Many people have mono-block amplifiers that are located in a different part of the room and are often connected to a different dedicated line than the one powering the D6000. The DENALI D2000/T was designed specifically for mono-blocks and it has a grounding terminal on the back of the unit. It is there to allow you to interconnect the various grounds together. Simply run a CGS grounding wire from the D6000 CGS terminal to each of the D2000 ground terminals. This eliminates or significantly reduces ground voltage differentials between multiple power lines. This concept can also be used to connect the amplifier's chassis to the D6000 if you are not using a D2000.
BTW, NEVER disable the ground connection from the Denali to the wall outlet!
stevebythebay
242
119
948
I currently have both the Denali 6000/T and DPC-6 connected via Shunyata HC power cables to two receptacles which are wired to a single 20 amp dedicated line. The Spectral 400 amps are individually connected to the 2 HC receptacles on the Denali. Each is being floated via Synergistic Research cheater plugs, as I've experienced hum if I don't use these.
I'd certainly like to know if I should connect the DPC-6 into an available Denali receptacle. Any benefit or not in doing so.
And should I remove the cheaters to verify that my system no longer displays any ground loop hum or not. I know that adding anything between a receptacle and cable is likely to impede or otherwise adversely affect the free flow of electricity or have other effects.
Just trying to get the best performance from my system.
