Long DC cable
Maril555
388
346
370
I need to make a longer DC cable for the linear PSU that feeds TT motor, as it induces hum in SUT/Phono stage,
and wondering if there any downside on having a long DC cable (15 ft)?
Thank you
Hear Here
744
460
155
Portsmouth, UK
Thank you
The current being carried would be minute, even with the low DC voltage, so you don't need massive gauge cable, but consider getting a screened cable to be sure that no external interference reaches the TT motor. It's much too heavy but the construction of Belden 19364 is ideal as it has a screen and a drain, as well as 3 main cores. A lighter 2-core cable would be ideal if you can find one.
Maril555
388
346
370
Thank you,
I'm thinking Gotham GAC-1 Ultra Pro Star Quad (that's one of the raw cables Ghent Audio is using for DC cables), which is pretty flexible and has 5 layers of shielding.
The current is not a concern, but a possibility of a long cable to be more prone to EMF
Hear Here
744
460
155
Portsmouth, UK
I'm cerainly no expect in anything vinyl, but that would seem to tick the boxes you need ticked. It's said to be a very flexible cable designed primarily for microphone use, with all 4 conductors individually screened, plus another screen around the bundle of 4 conductors.
Others her may be able to offer other suggestions.
