LP flattener
rDin
231
197
130
55
I’ve probably run 200+ through my DF0-1iA and have melted maybe 5. Two of those were translucent red. Now I know to cut the cycle short for colored vinyl and it’s been fine.
Interesting. What heat setting? I may see if I can deliberately damage a record, just to get the data point...
rDin
231
197
130
55
The AFI also has the “Relax” function which makes a noticeable difference !
That does intrigue me. Is it really more than just the result of heating a record and letting it cool? Or is it doing something more? Repeated low heat/cool to "flex" it???
mtemur
1,416
1,362
245
48
Another data point, but I also haven't lost a record with the Orb either, so far... All types been through from run of the mill to MoFi One-Step, UHQR formulations and all variations of weight, colour and temperatures.
+1
djsina2
1,172
1,018
243
I always use Low setting. Now I stop it after 30 or 60 min for colored vinyl.
Reactions: rDin
joeling
177
51
335
Well, I have had my ORB DF-01iA+ (improved model over the DF-01iA non + model) since November 2022. Since then, I have put through about 15-20 records. So far, it's 100% success rate for me. For more severely warped records, I put it through the cycle twice. I use the 4hr cycle on medium. There seems to b 2 temperature gradients in this cycle. Pretty happy with this purchase.
rDin
231
197
130
55
I only use LOW these days. If a record (rare) doesn't flatten then it gets another run at MEDIUM.
Reactions: djsina2 and joeling
Kingrex
2,949
2,429
350
What is the temp of your machine. Mine is factory set at 125.5. I left it there. Flattened about 4 records. Never an issue that was the flatner.
cbondcarolina
1
38
United States
Yes I have years of experience with Vinyl Flat....years of unsatisfying experience. Hit or miss, and some mangled lps to boot. I would imagine a similar outcome with the UK Record Pi. A Hoffman thread on it indicates the same sort of experience I had with Vinyl Flat.
I would recommend to anyone getting the Orb that they also use felt lp sized spacers sandwhiched around the lp, which ensures no contact of the lp with the glass. I have flattened at least 100 records using it in this manner, including supposedly un-flattenable ones that weight under 140g...
I have done this same thing using the Orb. I had two felt spacers left over from the Record Pi that I used prior to the Orb, but I don’t love them as they’re a bit flimsy. Do you remember where you got your spacers? I’d like a better quality than the two I currently own.
rDin
231
197
130
55
What problem does using the felt solve? And what might it create? I've used the "naked" Orb on hundreds of records without any issues...
Reactions: mtemur
djsina2
1,172
1,018
243
I’ve used the felt. Don’t think it serves any purpose unless your record has no groove guard.
