MIT Oracle V 1.2 or V 2.2 vs Oracle HD-90.1 or SHD 120
caliaripaolo
493
194
950
Italia
please, need your advise on speaker cables on title. They have to be inserted on Spectral DMA 260-Avalon Eidolon chain.
IC cable is Oracle Matrix 50.
Conventional wisdom says the HD series will outperform the v x.2 in this application. Based on this wisdom I traded in my v1.3 IC's for MA-X.
I'm running Matrix 50c with HD90.1 speaker cables. A great deal better than spectral ul770 11 cables, but they should be, with the cost differential. Differences noted between the two are more transparency, better soundstage (width and depth), quieter, and more detailed. As to the difference between SHD120, don't know, but edorr is right I believe- I've been told you should use the HD speaker cable with Matrix 50 ics
