well, I got to hear the Select 2 with mono power bases over the weekend at a dealer - again, this is the best "digital" i've heard and just doesn't sound like digital. stunning nuance, flow, and resolution where you feel that you are part of the performance. i know some may say I'm speaking hyperbole, but I really feel that MSB is simply in a different league.
I also heard the Formula dac in the same session - it sounded like a tube dac to me (not my cup of tea) but I can see its appeal for others. however, it wasn't particularly close to the Select performance-wise.
Quite surprising regarding the Formula , it sounds anything but like a tube DAC to me .What was the rest of the chain ? That may help clarify ....
Perhaps tube-like is a better descriptor, but sure - the Aqua was through the Select's passive preamp to an ARC Ref 150 on YG Sonjas.
I found the Aqua was a bit closed in and more intimate, with a heavier focus on the midrange. It also projected more forward like some tubes do. It was very nice/smooth on vocals, but I didn't care for it on complex electronica. It also was a step behind in the bass department.
Yes.
ok, that makes sense........relative to the MSB Select II, with 2 power bases.
the difference in textural nuance might lead one to think 'tube-like' with the smoother/glossed over presentation. but it's a matter of the context.
Mike, I am enjoying this thread and want to bring it back to you and this MSB DAC. You wrote somewhere earlier in this thread that you compare all incoming digital source components to your analog front ends, both vinyl and tape. I presume that means you use those sources as the references against which you judge the MSB. What specifically do you listen for: how convincing it sounds, your musical involvement or enjoyment, specific sonic attributes, or is it something else? This MSB Select II DAC seems to come closer than others to the qualities of your analog that you so enjoy. Could you talk a bit more about that? I am also curious to learn what "This sounds best to me" means to you.
May I ask you to describe the ways in which the MSB and NVS sound like your experience with live, unamplified music? Which one sounds more real or convincing to you? Does that even matter to you, or do you see these as different interests/activities? Is a reference to actual live music not as critical to you in this evaluation stage? How does it matter to you in terms of long term listener satisfaction?
I have enjoyed reading your writings about your system and room improvements over time, but I don't really have a sense of what drives your obvious passion and momentous efforts to constantly improve what you have to ever higher levels. Is it to discover and own the current state of the art? You seem to be on a constant path, always moving forward toward the next improvement. Ordinarily, this would imply to me that you are not satisfied with what you have. But, I have been following your posts long enough to understand that you are immensely satisfied with your current gear and could stop any time, and yet, you continue onward. It is remarkable.
Peter,
thanks for the kind words. today has been busy at work, and tonight I have relatives in town and am tied up. I appreciate your thoughtful questions (you (and Micro) do ask the hard/deep questions) and don't want you to think I'm ignoring you. I will dig into this as soon as I can.
and I will repeat; my recent comments were directed to Brad's single comment, and not intended to slow the overall flow of the thread.
Mike, have you given any thought to my post?
