Mullard 12AU7 versus Hivac CV491
16,224
13,690
2,665
Who has compared the sound of these 12AU7s?
What is special about the Hivac CV491 KB/HR compared to Mullard 12AU7 long plates from Blackburn?
Thank you.
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
1,619
1,490
553
Tbh I had never heard of this Hivac valve so I googled it. There’s an extensive write up in the headfi link below.
16,224
13,690
2,665
That's a good write-up, thank you!
geetee1972
80
171
98
51
Ron, can't be a coincidence that you're asking about the Hivac 12au7 at the same time as I'm looking at buying a set myself. Have you also found where they're being sold?
I might plump for them (the retailer is actually 2 miles away from where I live!) and write them up. If you're interested I will let you know my thoughts.
16,224
13,690
2,665
I have found them thus far only from Nguyen Thanh Tuan at Hanoi Tubes on eBay.
geetee1972
80
171
98
51
I have a pair playing now in my pre-amp and they are superb. Exceptionally musical and well balanced across the spectrum. Bass is significantly enhanced with really weight and slam compared to my stock 12AU7WA tubes but also the mid range has been endowed with a sweetness and lucidity to it; it's more composed so it has sparkle but not brightness. Not sure how justifiable the £700 price is but that is for a matched pair and that is considerably less than half what Hanoi Tubes are asking ($1100 per tube!)
16,224
13,690
2,665
jonyung
33
31
248
Hi Ron
The Hivac CV491 KB/HR ( in gold lettering) in black plate are special sounding tubes: They are warm, yet sounding clear in a sweet kinda way, abit like the black plate, square getter brimar tubes of the same vintage. They sound less "bloated" than some mullards in certain systems. If you like the sound of the Hivacs, there is no replacement, there's a uniqueness to tits sound profile,
The Longplate, Sq getter Mullards circa around1959 are nice, its got all the signature warmth of the mullards, but without the bloatedness of some later productions.
The Black plate versions are even better, but they are "unobtanium", so don't bother!
Hope this helps
16,224
13,690
2,665
Yes, thank you!
I would like to find four NOS of those.
geetee1972
80
171
98
51
Hi Ron
These are exactly the ones i just bought and am currently listening to. They have one pair left priced at £700. I'm tempted to snaffle them up as a spare!
Langrex Hivac 12AU7
Langrex is 20 minutes drive from me.
16,224
13,690
2,665
I think you should grab that second pair!
jonyung
33
31
248
Yes, thank you!
Just beware that they tend to be more "Hissy" than tubes of similar vintage. I don't mind it, if you like the specific sound profile, but don't buy it if you favor "pitch dark silence" and total absence of high freq hissing...
sparkie
80
17
10
Rapid City, South Dakota
HIVAC was made as a joint adventure with Mullard and RCA to make OEM branded tubes, So OEMs like Matusita, Conn, Baldwin, Heathkit, and even RCA will most likely have the same tubes. Has anyone looked. The difference you will see is the color of the cord around the pins at the base, and glass draw marks. Getter could be D or O type, but most of them were D getter before they decided that shape didn't do anything better than the O getter. The shape of the plates and the holes in the plates make most of the sound. The black tungsten alloy plates that was special to the manufacturer is a dead giveaway.
