New Pilium Gear!!!!
Pilium Audio Leonidas perfection !
Thanks for posting. Is that Siltech Triple Crown and Entreq Pluton as part of the system (Entreq not connected)?
Another happy owner here. Pilium Ares (pre-amplifier) driving a set of Pilium Poseidon. Really magnificent!!
Great system. Can you elaborate a bit about the differences with your previous setup?
First pic from Munich today, with Magico A5's, Pilium Alexander/Achilles, VYDA cables.
May I know why only use a5 not other higher end magico models?
The A5 was introduced during Covid and there was never really an opportunity to properly announce/show the A5s.
The M6s are in the Solution room at Munich as well.
BTW, the A5s are selling globally in LARGE numbers.
Reactions: Alrainbow and kmyl
I see, good to see all audiophiles can finally get together and listen to something in person rather on YouTube :D
Does it has standby button? If not, need turn it on all the time?
Thanks
There is no standby mode on any of the Pilium amps.
so, need to keep turn on all the time? Not enviromental friendly and heat generation problem
You can leave it on for days and it is cool to the touch. Big heat sinks and the circuitry runs cool. Takes very little time to warm up for optimum sound. No reason to leave it on, just turn it on when you want to use it.
I wonder what’s a good amp stand board for Pilium?
I am using a Franc Audio amp stand for my Achilles with excellent results
Did you compare it with solid floor or other amp stand? Any improvements noticed?
