Peter A.’s System: A Perspective on Natural Sound
morricab
9,532
5,070
1,228
Switzerland
I had before 2 Kondo Souga in passive biamping, that i love,but i found more natural the sound of CH in my system.
Strange but is the reality
Anyway i would like to buy some Kondo or ANJ for my second system
Give Aries Cerat a try . You might find it combines what you like about CH and Kondo all in one package...
Reactions: Andrew S.
assessor43
312
194
128
When I think of Natural sound, I think of a sound that does not sound like a PA system or instruments just sounding like noises and not instruments. I also think of a sound that is not so etched. for example, many times I sit within the first four rows at Severance Hall. The instruments never sound like I can pick out each violin or Viola player and so on. The clarinet sounds just like it should just where it should be, not overly forward or as in many systems the horns sound like they are right in front of you. They should not. They should sound like where they are located and in proper proportion to the rest of the orchestra and the correct size of sound. Sometimes I hear peoples voices that sound 7 feet wide on some systems. They should not. they should sound like a real persons voice and the correct size, not ampified like through a PA system.
PeterA
12,669
10,942
3,515
USA
Great post. You make good distinctions between natural sounding systems and systems that sound like hi-fi.
tima
5,865
6,937
1,400
the Upper Midwest
Lucky you! A fine hall in a nice setting.
I find sonic characteristics like you describe can come from a system and also be a function of the recording itself. Use of multi-miking and the subseqent mix can lead to spotlighting a particular instrument or section causing a less-than-natural perspective. (Deutsche Grammaphon raises its hand.) When a performance includes a soloist (concerto) or one or a few vocalists at the front of a stage, it can be tricky to get the proportions as they are heard live. Lesser quality systems can 'amplify' the disproportionality. As my system improves DG recordings improve with it.
assessor43
312
194
128
that is very true.
Al M.
8,810
4,553
1,213
Greater Boston
Sure, but the spotlighting of soloists is intentional and apparently is supposed to give you the best seat in the house. I have nothing against that, frankly. The famous conductor Herbert von Karajan was known for loving recordings and perhaps the manipulation of them (he recorded for Deutsche Grammophon). When once asked if live concerts aren't still better, he apparently replied: "For whom?"
Same here.
