Project Primary E turntable slightly distorted
jotavinyl
5
2
3
56
Madrid, Spain
Hi!!
I recently got a ProJect Primary E, which has got very nice reviews for the entrly level segment.
Question is: I hear the sound a bit distorted. In fact I returned a first Primary E in which the distortion was unbearable: it made the turntable directly not usable.
Two days later I received a second one: the distortion level is by no means that of the first one, but I've got quite a trained ear (I am a drummer, piano player, bass player and producer) and I notice a slight distortion in the left channel at times...
Is it related with the stylus? It comes bundled with an Ortofon OM NN, which I think is low-end entry level as well. Perhaps an Ortofon Pro-S would improve?
Or could be that the turntable is delivering too hot a signal to the amplifier?
I am using the MM position in the amplifier PHONO input (a Sansui A-60), see attached. Is that correct?
mtemur
1,416
1,362
245
48
Could be anything but stylus looks more like the culprit here. I recommend trying a better cartridge. Swapping amplifier (phono) also worths considering.
Reactions: jotavinyl
jotavinyl
5
2
3
56
Madrid, Spain
Thanks for your reply. The turntable mounts an Ortofon NN, as shown in the attached box picture. Would you recommend changing the stylus only or the full cartridge, as I seem to read? In such case....which cartridge would you recommend for this Primary E model?
Regards...
mtemur
1,416
1,362
245
48
Regards...
I recommend changing stylus first cause it’s removable. If it doesn’t solve the problem changing cartridge and checking tonearm’s side force seems like a good idea.
mtemur
1,416
1,362
245
48
Which stylus would you recommend then?
Thanks for a reply...
To try a new example of the same stylus will help to identify the problem but IOT achieve better details with lower distortion MicroRidge or equivalent would be my recommendation. I hope this helps.
jotavinyl
5
2
3
56
Madrid, Spain
MicroRidge stylus? Perhaps could you point which Ortofon OM compatible mounts these styli?
Regards....
