Pure Audio Project upgrades and tweaks
Starting this thread to discuss Pure Audio Project open baffle speakers, upgrades and tweaks. @Kingrex - if you have had both the horns and Coax10, I would be interested in hearing how they compare. And I copied your earlier post below.
What cables upgrades did you use? And can you share a picture of where you located the crossover? Is it attached to something else, or sitting on the floor? I was wondering about the height of the midrange/tweeter and if I should rake the front up. My system will be the Trio15 Coax10, Playback Designs MPS-8 source and Pass Int-25 amp. I'm still waiting for my walnut baffles to ship from RJ Millworkers.
You have to get the updated speaker cables. Its critical.
And , you have to separate the crossover from the frame. Again critical.
If the crossover is touching the frame, the music is very smeared from the intense physical vibration.
If you use stock, instead of upgraded cables, you loose life, air and bass. Less coherent.
The speaker is very good with these tweeks. You don't need to futz with any caps or reaistors with the Coax crossover.
You need to be patient. They take 500 hours like any speaker to break in. 2000 or a year to really be there. I actually put my coax in the basement connected to a class D amp and laptop for week and let it rip sitting on the floor. I would go dowm 3 or 4 times a day to switxh the album and volume.
Also, mine sit on a 9 inch tall very heavy block of wood that sits on fiberglass insulation. A rug would also work. Massive improvement in bass. Just shocking. And, it raises the center of the coax much closer to ear height. Otherwise its too low and like sitting in a balcony.
The fabric over the top keeps the sun from striking the driver. That is all its for.
New layout:
I'll move the sub to the back wall, and the Passlabs will move closer to my desk. I have a rack arriving next week, to house the DAVE, Moon amp and Paul Pang switch. I like the Passlabs sideways TBH, they are very well built. Downside is I have speaker cables down the middle of the rug.
I can live with that. Must ensure the dogs don't come in wet and do a shake down!!!
2 large indoor plants in the back corners, curtains - done. ~The system is sounding really nice, will hook up the Passlabs end next week. They are warmer and weightier mids, amazing bass control and detail. They get warm, but not unmanageable.
The quintets look great in your room… really nice and integrated Legolas. My favourite thing with the pureaudioprojects is even with the huge ability to trim and refine they don’t point you into being hung up in an endless analytical loop… their characteristic default is into drawing you back into the music.
So some more tweaks.
I fitted 3 x Path Audio resistors in the wire wound resistor positions. And left the 2 Mundorf flat resistors as is.
Listening to the Quintet15s last night, it is quite a big change. More energy up top, and more detail in the mids as well. This suits my room and my front end, so very happy with the result. I could also happily live with them as stock I must point out, it is all about personal tastes and music preferences.
Reactions: christoph
I have 2 x Duelund Bypass caps to try next, so will report back in 2 weeks after this tweak has settled a bit. The Quintet15s are very uncoloured IMO, the gap between tracks of different music types and recordings is huge, unlike some of my previous speakers. The complete absence of box colouration helps of course, and the reduced room nodes / interaction with my room as open backed.
I also have amazing bass detail and depth, something that seems to worry those thinking about OB but worried about a lack of deep bass and lower energy. TBH I am amazed how good the bass is, really fast and detailed, no bloat, and seemlessly blends / keeps up with the Coax 10 and also it's Compression driver.
