What do you guys think is the ideal proportions of a medium size dedicated listening room ?
15x21 ?
the proper ration is 1:1.6.2.33. This is one of the golden ratio's not the only one and if the ceiling can be 10 instead of 9 it will make a differenceSince i will be constructing i will do 15 x 22.5 x 9
I think it's just about right for a medium size room.
I'm looking at houses with a very large basement where i could build my dedicated room.
With basement rooms, to the extent that the walls of the listening room would border the foundation, the walls will tend to be very stiff since they are concrete. The floor will also probably be concrete. This construction will tend to emphasize bass room modes, thus accenting peaks and dips in bass response corresponding to the room modes. Be prepared to use electronic equalization to tame these bass modes.
Also, you may find that few basements will allow construction of an unsupported expanse more than about 12 feet in one room dimension. Usually there need to be steel I-beams or concrete walls spaced every 12 feet or so to support the upper floors of the house adequately, and horizontal steel I-beam joists have to be supported down to the basement floor every few feet. That's why most large unfinished basements have a lot of vertical posts in the space. This may pose problems for constructing a basement room 15 feet wide without vertical pillars or posts interrupting the space. I'm sure there are architectural ways around this problem, but you should research this to make sure that constructing such a room is not cost prohibitive.
In my case, I was building a ranch home and initially planned a basement listening space of 20' x 26'. But when the architect mentioned the need for posts, I decided to build a narrower, 13' x 20' room. As other comments mention, such a narrow width can create problems for a a listening room unless you adopt a near-field listening strategy--which I did.
15x21 ?
(...) In my case, I was building a ranch home and initially planned a basement listening space of 20' x 26'. But when the architect mentioned the need for posts, I decided to build a narrower, 13' x 20' room. As other comments mention, such a narrow width can create problems for a a listening room unless you adopt a near-field listening strategy--which I did.
Hi guys i have found a home that i would like to purchase and make nice renovations.
Unfortunately the room where i could build my listening room is not ideal size : 10.50X16.50X9.
What wall should i choose to place my speakers in my case ?
I will do some serious room treatment since the room is not ideal.
Thanks.
In my opinion, the size is way too small. No room treatments can help.
I obviously know it's too small that's why i'm asking, but check out this guy's room : https://systems.audiogon.com/systems/5707
