Should the Q5 have stands?
Gregadd
1,809
1,850
Metro DC
I would not put an expensive speaker on the floor. Any other benefits?
If you were 8 ft tall or listened on a bar stool maybe. LOL.
Seriously though, why would you want to put a speaker heavier than a 600cc sportbike on stands?
Even the liberty bell rings. Stands don't have to add height.
Ah, so you mean footers instead of spikes. I hurt myself with the knuckle test on the Q5s. This speaker's enclosure is deader than the proverbial door nail. I have no way of knowing if going from the supplied spikes to something like their own Q-Pods, Harmonix or CMS RiZEs would change things much other than maybe transmitting differently to the floor for different bass creep.
The weight of it alone will anchor it to the floor. It doesn't need anything else.
If you're concerned about it's being ON the floor and you want to protect it from the one who vacuums the room, just put some nails in the floor to act as a "stop." !!!!!!!!!!!!:D
If you have floorstanding loudspeakers and would like to get very best performance out of them the first thing that you will want to do is mount them on Sound Anchor Bases. In addition to elevating your speakers slightly Sound Anchor Bases control the flow of energy into your floor and control cabinet vibrations so that you can not hear them. This clears up all kinds of artifacts that are usually blamed on electronics.
By allowing only the air to be stimulated by your speakers a much more linear sound field is produced. The highs are more pure , the mids are more clean, and the bass becomes more full and less one note in nature. The transient response of your system will be improved enormously. Music will sound less attached to your speakers and more natural.
Sound Anchors makes three basic styles of bases for floorstanding speakers. All of them are designed to be the best possible foundation for your speaker. We have developed several different strategies for resonance control in our products over the years. Our latest generation of floor standing bases incorporate all that we have learned. We increase the footprint size for stability, we spike them at the floor to mass load and further stabilize the system, and we fill the bases with various proprietary materials to absorb and control system energy.
So whatever floor standing loudspeaker you may have a Sound Anchor Base will dramatically improve your systems performance bottomed to top.
If we do not already make a base for your speaker we can custom-make one for it. An example of each of our three styles is shown on the side of this page.
There are some benefits.
