Silver cable break in
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
@GroovySauce
@Geoffkait thanks for reminding me about the XLO CD. Also when you say not enough oomph what is “enough”? Is it voltage, current, frequency or a combination? What is a good voltage or current level?“
The XLO track is a complex waveform with time varying frequencies. Played at moderate levels through speakers, so everything in signal path gets the treatment.
Reactions: GroovySauce
Republicoftexas69
Amir
859
644
160
45
Tehran, Iran
www.amiraudio.com
Reactions: nirodha
Audiocrack
2,187
696
1,158
this is 100% true.
Thanks Amir. However, I also experienced that for some cables - in my case the various Tripoint Audio grounding cables I am using - to perform at their best you do need a cable cooker. The current going through grounding cables is so small/weak that you do not (really) break in these cables by just using them in your audio set up.
Amir
859
644
160
45
Tehran, Iran
www.amiraudio.com
I think music signal is better than pink noise or any other form of high bandwidth signals like square wave or ...
My feeling is high bandwidth signals (applying by both cable cooker or Purist Break-in CD) will magnetize the system.
I prefer to play music for break-in.
If you use cable cooker it is not bad idea if you play de-Magnetizing signal in Ayre CD (track 7):
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
This is weird, Dr. Keith Johnson co-inventor of HDCD and Roger Skoff of XLO Cable Company assign Demagnetizing the system to Track 7 on their XLO Test CD, yet the Burn in Track is No. 8. According to the idea that a Burn in Track magnetizes the system. Wouldn’t that kind of negate the demag track?
“If it doesn’t make sense it’s not true.“ - Judge Judy
Amir
859
644
160
45
Tehran, Iran
www.amiraudio.com
I have listened to my system after using Purist audio Break-in CD and my feeling was not good. It seems those signals does not have good effect on my system.
this is my subjective experience.
I regard Spectral Audio so if you talked to Mr. Johnson about this CD please let me know.
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
I have no experience with the Purist Audio CD so can’t comment. I have oodles of experience with XLO Test CD. BTW the Speaker set-up track is to die for.
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
Have we forgotten anything? We forgot cryogenic treatment! Cryogenic treatment of cables reduces noise and distortion. This is especially true for silver cables, which we know can oft sound thin and bland before cryo and break in. That’s why most high end cable companies employ cryo as part of the process.
dinov
8
4
10
63
Destin, Fl
That’s their M.O. so to speak. Silver can be shrill, but keep playing through them because thats the best way to break them in. The benefits are detail and smoothness which can be very rewarding. Good luck.
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
Please note I said cryo AND break in. No matter how much you have in the end you would have had even more if you had started out with more. As Bob Dylan says at the end of his records, good luck to everybody. :)
curbfeeler
29
16
910
In my experience treating cabling with the Nordost VIDAR conditioner has always made for a significant improvement in sound quality. Especially interesting is the difference it makes in tonearm wiring. My interconnects are all Nordost silver-coated. Nordost advises that initial duration of burn in required might be as long as 120-144 hours. So, yes, silver plated cables seem to take a long time to condition.
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
That‘s weird, Nordost is one of the few high end cables that doesn’t cryo their cables during manufacture. Say, weren’t they one of the directionality deniers?
curbfeeler
29
16
910
The Nordost cables are marked with arrows on one end, so directionality must be of some import at the company.
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
That’s true, but they put arrows on cables only for the “directionality“ of the shield, not for “directionality” of the wire; both types of “directionality” should be controlled, ideally.
Holmz
Active Member
Apr 19, 2022
136
47
33
63
What is the hypothesis of what is getting “burned in?”
The conductor?
the insulation?
or something else?
What is getting magnetised?
(I thought Silver in particular was not very magnetic)
Geoffkait
Active Member
Feb 2, 2024
265
91
30
80
Falls Church, Va
The conductor?
the insulation?
or something else?
Most metal layers of CDs are aluminum but can also be gold, silver or silver alloy, none of which are magnetizable. And the metal layer is only a few molecules thick, anyway.in order to produce a significant magnetic field I suspect a lot more actual metal would be needed. Heck, the Earth’s natural magnetic field would undoubtedly be stronger.
The hypothesis that makes the most sense is that the polycarbonate layer acquires an electric static charge when the CD spins at high speed in air. I.e., friction of air molecules on plastic produces a persistent electric static charge. Moving a magnet across the surface of the CD produces an electric field that neutralizes the static electric charge on the CD. However, the electric static charge builds back up by playing the CD. That’s why it’s suggested a CD should be treated with a demagnetizer before every play.
Holmz
Active Member
Apr 19, 2022
136
47
33
63
What do CDs have to do with silver cables breaking in?
I suppose one would see bit errors then, with CDs?
And CDs used to hold data, would need magnets in their readers to prevent data corruption?
I am not even sure how, or if, a magnet would affect a static charge.
