The Dereneville Turntable Motor
Lagonda
3,515
4,827
1,255
Denmark
My new Derenville DAE-02-SP, delivered yesterday at my office.
Rainer has shipped it, in a bullet proof package which contained the flight case.
View attachment 70846 View attachment 70847 View attachment 70848
The quality and finishing level are very high as it was expected. The only issue is the connecting cable which is a bit too long but Rainer has made another one already. Rainer was very kind to include a flat belt too, in order to compare it with my EPDM belts
unfortunately I was too tired yesterday for the installation
Very cool !
Derainer
Industry Expert, VIP Donor
Apr 23, 2011
114
207
1,275
Germany
www.dereneville.de
I think you are waiting for the results. But I'll have to put you off for a few days.
To be honest with you: despite all the perfection - I made a small mistake during the assembly of this first prototype.
It would be pointless to go into detail here. Mistakes are human, right? That's why I want to be honest to you.
The revised engine will be returned on Monday. After that there will be first results.
Thank you and take care , Rainer
Vienna
my friend Rainer, mistakes are understood., especially the moment that the manufacturer is standing behind his product by taking swiftly all necessary actions to correct them.
Thank you once again and I am looking forward to receive the motor back
Vienna
I received back the motor from Rainer, yesterday.
the trial operation showed a huge improvement in terms of vibration and resonance management.
The motor run extremely smoothly and silently.
Due to very busy days I will probably install it on Sunday morning.
For the moment I can say that the controller’ s degree of precision, adjustability, functionality and convenience is second to none.
I have dealt with many motors’ controllers in the past and easily this is, by very far, the best. With confidence I would say that Rainer’s controller is a reference for the industry
Audiophile Bill
4,293
4,093
675
awesome - can’t wait to see the measurements
Jan 18, 2012
2,373
2,476
1,475
Drobak Norway
interesting that you can set acceleration and when the beast has started turning and reached speed it needs almost no motor power and will run ala Nottingham tt´s
Vienna
the controller is providing more adjustments than just accelaration. I have attached the manual where all the adjustments are described
  • BDA_DMS-5001_DAE-01 SP_E_V02.pdf
Lagonda
3,515
4,827
1,255
Denmark
Wow that is a well written manual, very comprehensive ! Amazing selection of features, mostly things i would probably not use ;) But it is nice to have it included, clearly Rainer put some serious thought into this product. It's definitely going to be interesting to hear your assessment of the sound compared to the excellent RöhNt system you already own. You already have extended experience with different motors and controllers, and a system that can translate the differences into music :)
Reactions: Derainer
Vienna
Initially i had the same thoughts with you in regards with features, but i now realize that i can have more torque ( higher gain) for e.g rock music saved at PU1 and lower gain for jazz saved at PU2
i think that they are very useful features
Reactions: Audiophile Bill
Lagonda
3,515
4,827
1,255
Denmark
I normally start up my TT an hour before listening, and don't stop it again until i finish the session, i have finally mastered the art of changing records with the platter spinning, the different counters for cartridge wear would be wasted on me :rolleyes: I though the gain settings where for accelerating/decelerating the platter. But different torque settings for different music sounds interesting, let us know if you hear a difference.
Reactions: matakana
bonzo75
22,650
13,687
2,710
London
If you use good quality records, stop the platter.
Reactions: Derainer
Lagonda
3,515
4,827
1,255
Denmark
I use a leather mat, i don't think the records are getting damaged. If i was going "bare back" on a metal platter i would definitely reconsider :eek: I thought Tang was doing the same thing.
Lagonda
3,515
4,827
1,255
Denmark
Reactions: PeterA
Derainer
Apr 23, 2011
114
207
1,275
Germany
www.dereneville.de
Warm up and run continuously is not necessary with this drive unit.
It runs absolutely constantly from minus 20 °C to plus 60 °C - right from the start.
There is no need to worry about the speed of rotation.
Thank you,
Rainer
Reactions: Lagonda
Lagonda
3,515
4,827
1,255
Denmark
Thank you,
Rainer
That is your motor Rainer, but the rest of the TT can change parameters quite a bit with temperature of bearing and air-supply system.
Reactions: adyc
Vienna
And here comes the beauty of Brinkmann Balance heated hydrostatic oil bearing...
Lagonda
3,515
4,827
1,255
Denmark
That is truly a nice feature on a TT with a lubricated bearing. My air bearing gets the air from a high pressure shop compressor with a 100 L expansion tank, far away in a separate sound proof room in the attic, that changes temperature significantly with operation. o_O
