The Discrete DAC – Firmware Update
osadu
2
71
GA
I have an MSB Discrete DAC on the way. Very excited. Part of my current system is Bryston BDP-3 digital player and an Innuos Zenith MK3. At the MSB website, it says in order to update the Discrete DAC firmware, one should download the file "MSB_DiscreteDAC_ver_23.wav" and add the file to a bit perfect playback software. It also says that the file must be played by a bit perfect source. Here is my question. Can I download the "MSB_DiscreteDAC_ver_23.wav" onto a USB thumb drive, attach the USB thumb drive to the Bryston BDP-3, and connect the Bryston BDP -3 player to the MSB Discrete DAC using XLR digital cable and play the wav file through the Discrete DAC to update the Discrete DAC firmware. Or, alternatively, should I load the wav file into the Innuos Zenith MK3 and connect the Innuos to the MSB Discrete DAC and play the wav file through the MSB Discrete DAC to update it? Or am I totally lost. Please help me.
Osadu
16,221
13,686
2,665
Welcome to WBF, osadu!
I think you will be happy with the MSB!
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Either method will work, as long as the Bryston's output is truly bit-perfect. I would just drop the file on the Innuos and play from there.
Reactions: barbz127
barbz127
57
12
13
39
I plugged my msb into the PC and did the update via foobar rather than fluff around uploading the file into roon via the antipodes.
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Yes, if your MSB has the USB input, then plugging a PC and playing it back works too, you just have to make sure the app playing the file does it truly bit-perfect (like foobar).
