General, are you sure you don’t want to add some acoustic panels or tube traps? That room does not look sufficiently high-end without them.
Dear Ron,
Thank you for your kind words. You must hear the Drina or Elysium amps to truly grasp the difference.
With regard to the tonearm the devil is in the detail.
The combination of the Viv Labs 7", Swing head-shell, active cartridge and no RIAA is the best tracking best sounding device known to me.
I am on record for saying that the culprits for groove damage are stylus profile, side force and dirt.
Kindest regards,G.
Dear General,Dear PeterA,
The wooden panels were built at the same time as the Mayflower and the Globe theatre. King James the first ignored acousticians advice on tube traps, he insisted on the aesthetic over the acoustic.
The Bard concurred and the room was born.
Kindest regards,G.
Dear Ron,
Kindest regards,G.
Dear Ron,
Kindest regards,G.
I still don’t understand about the RIAA. It is encoded in the record so that bass signals encoded are much smaller amplitude than they need to be lest the needle jump out of the groove. There has to be equalisation or the frequency response will be heavily tilted upwards with increasing frequency.Dear General,
Given the rarified atmosphere here, I feel a level of formality is appropriate. Could you please expand a bit on your comment about the tonearm/head-shell/active cartridge/no RIAA combination and why it tracks so well? I presume the active cartridge has the RIAA compensation built in. What is the Swing head-shell? Does it have a pivot at the mount for offset angle and zenith? And I am curious about such a short tonearm with its tracing arc.
Finally, I understand about side force and dirt causing groove damage, but I want to learn more about the effect of different styli profiles. Which are good and which are bad, and why? Thank you.
Sincerely,
Peter
My thoughts too, Brad. I'm also curious about the head-shell spring adjusting as it moves toward the inner groove as the skating force increases. Perhaps it compensates as it goes along like the SME spring-loaded bias. The advantage is that it is at the headshell, closer to the cantilever/suspension than far away at the tonearm pivot.
Also, how does the tracing error of the 7" arm compare to longer arms? It seems the tracing arc is radically different (more curved) from what the General was used to with the linear tracking arm, ie zero error. I would like to understand more about his observation that his set up is the "best tracking device known to (him)".
Agreed. It takes quite a room to humble some of the equipment in this space.Love how equipment is neatly blended in, in a non-showy-trophy pieces looking style
.| Steve Williams Site Founder | Site Owner | Administrator | Ron Resnick Site Owner | Administrator | Julian (The Fixer) Website Build | Marketing Managersing |
