I'm pretty sure he means three-phase power.
Actually the UHC version (or so called export version) of the ML No.33 has a different power supply than the HC version (US version). The UHC version required a 35A 230V circuit and came with adapters so you could connect them to either a two phase or a three phase electrical wall outlet for the power grid.
Also Sovereign Audio The Sovereign can be connected to a three phase electrical line.
Do you have a 3 phase power service in the building you are using the amps in? You usually only see that in industrial buildings. If you do then you would just need to make a cord with the right wire and fittings. Look at an industrial supply website for parts. I'm not sure what else you would have to do internally to the amp though.
I live in Norway and pretty much all houses here have three phase 230V power available. I would prefer to use the original Madrigal equipment for this.
Not sure how likely it will be to find an original 3 phase cord. Does any of your other equipment run on 3 phase power? What is the benefit of using 3 phase power for audio?
We are not talking about a cord. The power cord on these amps are hardwired.
From what I can see on the net Norway's 3 phase voltage is 380 volts. A 3 phase power cord will have 4 wires. 3 wires for the 3 phases and one wire for ground. If the power cords on your amps don't have 4 wires in them then they wont work. An adapter will not add a wire for you. From what I understand you can use an adapter to go from 3 phase to 1 phase but not the other way around. You may need to have the amps rewired and even then they would have to work on 380 volts.
Are you thinking of a center-tapped 240 Volt system? That would be - Hot(black), Hot(red), Neutral(white) & Safety Ground(green) .************
The UHC version required a 35A 230V circuit and came with adapters so you could connect them to either a normal hot, cold and ground line or a three phase line.
Interesting information.i owned No. 33's for a year or so. mine were 120v. the No. 33's also came in a UHC (ultra high current) version that required a 220/240 volt plug, as well as some jumpers (and changes to fuses as i recall) changed inside the amp. so you could run it either way and they were the same amp. this was 12 years ago for me so my memory may be a bit foggy now.
