Vivid Audio: Moya M1 New Flagship
LL21
14,432
2,523
1,448
Specifications​
Vivid Audio MOYA M1
Configuration​
5-way, 13 driver system​
Cabinet material​
Carbon-reinforced balsa-cored vacuum-infused sandwich composite​
Standard colours​
Piano Black, Lexus Pearl White, Oyster Grey Matte​
Bespoke colours​
PPG automotive colours vailable on request​
Drive units​
High Frequency: D26DLC – 26 mm Diamond-like Coated alloy dome unit with Tapered Tube Loading. Ultra-high flux radial magnet system​
Upper Mid Frequency: D50DLC – 50 mm Diamond-like Coated alloy dome unit with Tapered Tube Loading. Copper shielded radial magnet system​
Mid Frequency: C100SCu – 100mm carbon fibre reinforced alloy cone driver with Tapered Tube Loading. Copper shielded rare-earth radial magnet system​
Lower Mid Frequency: 2 x C175-76 – 175 mm carbon fibre reinforced diaphragm with 76 mm voice coil with rare-earth radial magnet system. Tapered Tube Loading​
Low Frequency: 8 x C225-100H – 225 mm alloy diaphragm with 100mm voice coil in 45 mm gap rare-earth radial magnet system​
Bass loading​
Exponentially Tapered Tube enhanced bass reflex​
Sensitivity​
93dB/2.83V@1m​
Nominal impedacnce (Ω)​
5 nominal, 2.5 minimum at 40 Hz​
Frequency range (Hz)​
-6dB points: 19 Hz – 42,000 Hz​
First D26 Break Up mode:​
> 50,000 Hz​
Harmonic distortion
(2nd and 3rd harmonics)​
< -60dB > 100 Hz​
Cross over frequencies (Hz)​
125 Hz – 550 Hz – 1,700 Hz – 4,000 Hz​
Power handling
(music program) watts rms​
3,000W​
Loudspeaker dimensions​
1,660 mm (H) x 660 mm (W) x 1,210 mm (D)​
Net weight​
346 kg (each)​
Shipping dimensions​
Shipping weight​
1,084 kg​
