What is the best 5U4G ?
dminches
3,482
2,859
1,410
I don’t think you are in the US or I would send you a box.
Reactions: howiebrou
dminches
3,482
2,859
1,410
Uk Paul
516
183
955
UK
Yes but with more plate voltage you are changing the operating points of the stages... that's the truth! Do you have a schematic of the H3000 that you can observe if the rectifier you are changing can is suited for using it in this design?
Musical regards
No, so I ask the designer..
wcheng
13
5
908
San Diego
The kr rk 5u4g looks kind if large. Does it fit in the allnic h3000 without modification? I've tried the siemens metal base gz34, mullard 5ar4, Philips 5r4gy, rca 5r4gy, and the gec 5u4g in my allnic h3000. My favorite is the gec 5u4g followed by the rca. The rca seems a little more neutral with more precise image/soundstage but the gec has that magical tube tonality with a deeper and more layered soundstage.
Reactions: advanced101
advanced101
247
179
233
I guess I’ll find out.
advanced101
247
179
233
How many hours should you put on a Rectifier tube before making evaluations?
dcc
662
1,303
1,230
Continental Europe -
Hi. It does. I used to have the KR Lampizator Anniversary and I replaced it by the KR RK without any issue. The KR RK is even better.
Reactions: marslo and bonzo75
bonzo75
22,650
13,687
2,710
London
Yes the RK is really much better transforms the Allnic
Reactions: wisnon
advanced101
247
179
233
I only have 20 hours on the RK in my H3000. Very interesting sound, different than the Tung-Sol I have. Sound is airy, big, hyper detailed. Right now it lacks tonality, warmth, decay of instruments and bass. Almost sounds like bad solid state, minus the airiness. I ordered an RCA Double D-getter last night to continue comparisons. Did anyone notice a change after a certain amount of hours with the RK? I’m going to just leave it on over the weekend.
bonzo75
22,650
13,687
2,710
London
Usually the bass and Midbass is what is improving with the recti. If it doesn't open up, let me know if you want to sell might have someone interested. Sometimes certain valves are just not a fit with downstream electronics
advanced101
247
179
233
Thanks, Ill leave it on over the weekend, that’ll give it 50+ hours.
Uk Paul
516
183
955
UK
Your H3000 PSU is different to mine and others, what age is it? You have 2 x tubes, what is the smaller tube? And no tx casing?
advanced101
247
179
233
That second tube is just siting there, I took it for scale when I first got it.
But, I don’t have a TX casing. Ill have to look into that.
Uk Paul
516
183
955
UK
Oh yes I can see the pins now, :)
