Wilson Audio Submerge Subwoofer
Zeotrope
1,796
1,415
230
49
France, Canada
So? As with almost everything in this subjective hobby each view has its adherents and proponents.
“So”? So Wilson should have made this an option. I don’t understand why you seem to be arguing against this. I happen to agree with PS Audio and REL (as do you), that high level inputs are better when integrating a sub with existing speakers.
For a $30K+ sub it’s unacceptable. It’s long been known that Wilson rebadages subs in their lower end line, and I suspect this is a rebadged plate amp and driver as well. They should at least rebadge an amp with high level inputs, or add their own, which is dirt cheap and simple (add ~100K resistors and connect to low level inputs).
Look- I own Wilson speakers so I do like the brand, but I’m going to call them out on a bad product when I see it.
Reactions: XV-1
16,221
13,684
2,665
  • Love
Reactions: itay123 and Johan K
itay123
169
260
65
Vision from the media player to the projector.
Audio from the media player to the EVO-707.
Simple…
What player do you have?
at the time, I was thinking about the Krell HDMI 4K HDR Switcher
Have you tried it?
itay123
169
260
65
For plenty of people running a full range analog signal through DSP is totally anathema. I vote for not relitigating the whole DSP thing.
I agree. That's why I wrote 'for digital' sources ;). I also don't like converting an analog signal to digital; but if it's already digital, why not?
Even with DIGITAL I wasn't too impressed when I listened to 2CH.
When I had Trinnov alt16 at the time,
but I had a completely different setup,
I'd love to try again.
sigbergaudio
145
114
45
Oslo, Norway
www.sigbergaudio.no
Conspiracy theory: The idea of recommending high level outputs is due to the fact that REL at least originally had many customers with systems where this was the only option. The follow-up recommendation (for the same reason) is to not high pass the speakers and just use the sub to complement the very lowest octave while the speakers still played full-range.
In reality, and with more modern systems, the clearly superior route is to connect the subwoofer(s) with XLR or RCA, and also high pass the speakers. This way you can improve the dynamics of the speakers and utilize the subwoofers to enable a more even bass response in a wider frequency range (at least up to 80-100hz).
Zeotrope
1,796
1,415
230
49
France, Canada
How do you mean use both high and low level? Won’t that send the same signal x2?
sigbergaudio
145
114
45
Oslo, Norway
www.sigbergaudio.no
Sorry for being unclear. With "high pass the speaker" I mean to have a crossover that roll off the mains at for instance 80hz, allowing the subwoofers to play up to that frequency. As opposed to subwoofers only covering the lowest octave (to avoid overlap with the mains).
So only low level outputs, and do not send full range to the speakers. Bass to the subs, the rest to the speakers.
