wilson speakers with audionet humboldt
goodsource
6
44
are there any folks who use audionet humboldt integrated amp with any wilson speakers.
would love to hear some thoughts and feedback around this.
goodsource
6
44
folks even if not paired with wilson speakers, are there any audionet humboldt owners. can someone help describe the sonic characteristics and ownership experience for the saeme
peter pan
44
34
18
23
hey friend, you cant do any better.
i do own the humboldt and it is a fantastic pairing with wilson speakers.
actually there is no better amplification for wilsons than audionet sciencist series.
LL21
14,430
2,518
1,448
You have by all accounts an absolutely sensational preamp. Have you considered the matching sensational Constellation Hercules amp? (Not that your HDs arent already pretty great!)
peter pan
44
34
18
23
or vice versa...., "goodsource" owns the nagra hd amps, so why not add the hd preamp (the best preamp available today imho).
however, i do own the humbold, had it paired with the tunetots, alexia2 and the sabrinaX. on the other side, i had the wilsons paired with other worldclass amp and for me, very convinced, there is no better for each other!
utterly satisfaying.
humboldts needs very long burn in, thats all
shakti
1,444
2,412
480
Cologne, Germany
100% agree, took some hours for Stern and Heisenberg as well to finally open up fully
peter pan
44
34
18
23
yes, takes time until the midrange beauty kicks in....but then, wow, the search has an end.
that said, two heisis are expected in two days!:)
Reactions: shakti
peter pan
44
34
18
23
all right, for two days now the heisenbergs are powering the sabrina x.
you can hear the more ohmps which makes the thing a bit more overhelming.
while the sound seems to be identical, i do prefer the humboldt for the moment. more precision and even more beautyful colors.
lets see what the burn-in will change.
shakti
1,444
2,412
480
Cologne, Germany
you describe my Stern & Heisenberg listening for the first hours,
ist definitely takes a lot of hours, I used them 2 weeks in nearly 24/7
Now its fine.
peter pan
44
34
18
23
yes after burning in, they are heavenly.
somehow the same as humboldt but with even more slam, incredible. the added power helps a lot at higher volume and also at lower volume.
Thieliste
815
296
360
53
Hi guys, would like to know if the Humboldt could drive pretty difficult speakers like my Thiel CS 3.7s ?
My local Audionet dealer would be willing to do a shootout between my Diablo 300 and the Humboldt on my speakers.
My guess is that my Diablo 300 is much more appropriate for difficult load speakers as opposed to the Humboldt but it would be worth trying.
musicfirst1
504
310
395
Canada
www.musicfirstdistribution.ca
With all due respect, having owned the Diablo 300 and now owning the Humboldt, they both drive difficult loads very well, but the Humboldt, despite its more conservative power specs is significantly better driving more difficult loads. Here are the relevant specs for both Amps:
Gryphon Diablo 300:
  • Net Weight 84lbs
  • Power Output: 2 x 300W (8 Ohm), 2 x 600W (4 Ohm), 2 x 950W (2 Ohm)
  • Frequency Bandwidth (-3 dB): 0.1 Hz – 350 kHz
  • Power Supply Capacity: 2 x 68.000 microFarads
Audionet Humboldt:
  • Net Weight 135lbs
  • Power Output 2 x 320W (8 Ohm), 2 x 460W (4 Ohm), 2 x 650W (2 Ohm)
  • Frequency Bandwidth (-3 db) 0-700 KHz DC Coupled
  • Power Suppy Capacitance 800,000 microfarads!!
Don't get me wrong, the Diablo is a very very good Integrated, but the Humboldt is in a different league. The Humboldt can drive Apogees, MBLs and Sound Labs all day, most to 100+ db levels.
BTW, the Humboldt will drive every Wilson on the planet very easily. Wilsons are not that difficult to drive compared to the aforementioned speakers with virtually all modern Wilsons over 90db efficient.
Reactions: Hyperion and shakti
Thieliste
815
296
360
53
Gryphon Diablo 300:
  • Net Weight 84lbs
Audionet Humboldt:
  • Net Weight 135lbs
musicfirst1 thanks for your input, that's good to know coming from an ex Diablo 300 owner.
My speakers tend to be bright if not well paired, we'll see how it goes with the Humbold.
I'm also considering Gryphon Zena - Antileon Evo for a future upgrade.
musicfirst1
504
310
395
Canada
Even though they are ultra high bandwidth, similar to the Spectral gear of yor; neither the Humboldt or the Diablo 300 amps are remotely bright, unlike the Spectral gear which can be bright if paired incorrectly
Reactions: Thieliste
Hyperion
442
232
950
Stockholm/Sweden
You should definitely consider the Pilium Leonidas as well. Especially for a speaker where you might experience any kind of listening fatigue.
/ Marcus, www.perfect-sense.se
Thieliste
815
296
360
53
Thanks Marcus, yes i am planning to audition the Leonidas at some point if the Pilium dealer is ready to bring it to my place.
I already have the Humboldt planned for early december, we will make a shootout with my Diablo 300.
Reactions: Hyperion
_Alchemist_
144
76
93
Hi Guys,
I have an audionet humboldt with magico A3 and I'm looking to replace the magico's with possibly Sabrina x.
I do like the magico but they have one big flaw which is a timing issue between medium and bass drivers, therefore I can never get a perfectly clean low medium integration.
Does anyone here run this combo?
