I've seen you withstand the criticisms of others and persevere to do things in your own way and time..
Marc, he identified the problem correctly
Mark,I'm not sure how many of you are familiar with the Audio Bacon site, however Jay is a very industrious emerging reviewer with a keen interest in digital audio. I discovered his site several months ago whilst researching LPS for my router and he got in touch with me last Autumn with a request to review my digital cables. The review was published yesterday and you can read it in the link below as well as have a browse around other stuff on his site. Understandably I'm flattered by his evaluation, not least of all since I am keen for Sablon to be able to deliver customers a full cabling loom of very high performance, despite not having the resources of the 'big players'.
https://audiobacon.net/2019/01/04/sablon-audio-panatela-reserva-digital-elegance/
Mark,
I've barely spent enough time with the upgraded Reserve Elite USB cable since I left for vacation quite soon after receiving it but the improvements were clear straight out the gate. My impression may be influenced by the fact that I also went with the powerless option with the upgrade to Elite. However, I'll be surprised if the improvements wrought across the board were simply due to eliminating the power leg from the cable.
Direct comparisons showed a noticeable degree of enhanced resolution, better bass + bass resolution, much quieter backgrounds, plus a significant reduction in HF stridency.
For the nominal cost of this upgrade, I'm extremely satisfied with the results.
Incidentally, the ethernet cable makes a great i2s cable and has been used happily in Aqua / Metrum / MSB systems.
View attachment 47719My two Panatela Ethernet cables arrived, the long one to replaced AQ Vodka and the short one to replace Wireworld Platnium Starlight. Definitely an improvement on both those cables: a more balanced and fuller sound. I am impressed! Thank you Mark!
Mark was nice enough to make me a custom 30cm Ethernet cable, specifically with the source side plug facing up and the other side facing down. It now fits perfectly with my setup and sounds awesome!
A naive question - CAT6 cables only use two pairs of 100 ohm twisted cables - do specialty audio cable manufacturers of expensive cables using precious metals include the four pairs?
At higher speeds, and also for Power over Ethernet, more pairs are used.
Mark's Ethernet cable was my first experience of his knot of cables. Revelatory.
