thank you Peter for your videos. Have you used your phone for these recordings?I guess we are channeling each other today Bonzo.
So is it going to scramble our brains when you reveal?
I heard good things in both. A could go Hifi, but that can be a little hard to tell on a vid. However B has weight to vocals, they sorta bloom into something that sound less like a recording.
I'd have to adjust one of them to be more satisfied if I were you Peter. Tang might be right.?
So, I wrote this "I thought video A had much more authority, control, while the lack of showed in B, and B also had less energy and was rolled off at the top. For the choral it muddied up more, but I found it more natural in the start with only the woman's voice. There was some ambience in the second video."
I think because Tang tried to be oversmart and guess that B was 3012r, my guess is others thought that was the natural one and said B.
Apart from what people prefer from one video, can you please tell us what are the in room differences you heard between the two arms on that track?
I don't really understand your post, Bonzo. What does Tang have to do with it? Also, I described what I hear in the room listening live to the system in my post #66 above:
"The videos are more or less reflective of what I hear when listening live to my system. The 3012R sounds a tad more open with just a bit more energy in the higher frequencies and it seems to have more "air", while the V-12 seems a bit more composed with a fuller more extended bass. However, the 3012R bass seems more defined and nuanced, and overall more natural."
Peter, I was fairly certain based on our previous conversations of the sonic differences between your carts, that B was the Grand Cru. And I'm glad it is! I wasn't aware to which arm you'd mounted which cart, and I'm not familiar with the sonic differences between the arms anyhow. But I am glad I was able to pick out the Grand Cru from a phone video comparison. Regarding cart setup, I do think you'd like to own Analog Magik, Peter. I'm not suggesting that you use it to replace your ears. But when performing these types of experiments, it's good to know that you're able to quantitatively minimize setup variables between two arm/cart combos in order to be sure you're better evaluating the variables you actually intend to.
They are both the grand cru. Wow
They are both the Grand Cru, on two different arms.
Are people surprised by the results?
Phone recordings don't lie.
As I said the first time, the B sounds more like my 3012R with MS. I was not oversmart or anything. I just go by what I hear from the video. I have 4 3012R's. None of them ever exhibit more pronounce mid than other arms that I owned.
They do. Or, rather, they change the balance of sound, so the "whole" changes. Phones have a limitation in extension. They can also clip on some frequencies. Also, in a multiway, there are aspects of integration (or lack of) which are more subtle. While the attributes can be heard on a phone, their emphasis changes. So unless someone is looking for them, a listener won't react as naturally to them as he would in room. Energy levels are also different from the main system and the played back system. And you are looking for air and stage from the system in your phone playback, which is quite different from feeling it in the room. When on phone, you need to use both phone experience and gear experience, while in room, you just need to use more of senses, like a holistic sense.
That's why, sometimes you will just find much more disagreement with people on phone recordings than in real. This is similar to what happens at shows. If you take the ones who disagree to the private set up, they will agree more.
I play back what I record and hear in room, and certain things are representative and certain ones are not.
Also, we compared iphone 8+ and Samsung 10+ recordings of Mani's system. the iPhone was more organic and involving, and the Samsung sounded very clean and less involving. It's the same system. This adds a whole layer of misunderstanding to directly listening to the system
The most subtle effects are less pronounced on the phone, and sometimes the bad ones can be more pronounced. Given that a lot of hifi is about getting past the weakness, this can change balance. You might have focused on the weakness less in room, you might focus more on the phone. Again, this happens at shows too
Imo, phone recordings should be used as notes to convey what the listener wants to. They make more sense than words as they leave less to the writing skill/reading comprehension and go well with it. The flip side is the reader might ignore what the person sending the video is trying to say and use his own golden ear to use the phone recording as final.
