Klaudio's designer Peter Cheon is the creator of the Ultrasonic Record Cleaner & the Tangential Tonearm.
We can now announce the launch of the all new Magnezar Turntable.
Klaudio is a designer and manufacturer of original, audio equipment and a pioneer in high-end audio for over a decade. Many will know of us from our Ultrasonic Record Cleaner & our Tangential Tonearm.
We were thrilled to unveil the Magnezar at the Pacific Audio Fest last weekend, where audiophile got the opportunity to hear it for themselves.
The new turntable is a significant leap forward for music lovers. Magnezar represents the pinnacle of engineering excellence, pushing the boundaries of technology and design in the audio realm. This extraordinary turntable incorporates magnetic bearings and a direct drive system to deliver an unparalleled audio experience.
Key Features
Key Features
• Magnetically levitated platter
• Ultra quite direct drive motor
• Enhanced liquid stabilization and lighting
• Automatic spindle and peripheral clamping
• Dual tonearm support, including Klaudio tangential tonearm and laser pod
• Adjustable platter speed: 33, 45, & 78 rpm
• Aluminum construction
Featuring a platter that floats entirely on permanent magnets, Magnezar eliminates the need for traditional mechanical thrust bearings. The result is an unprecedented level of smoothness and precision in audio playback, captivating listeners with its remarkable fidelity and immersive soundscapes.• Ultra quite direct drive motor
At the heart of Magnezar lies an exceptionally quiet direct drive motor, ensuring a whisper-quiet background for an unparalleled auditory journey. Complementing this innovation is the inclusion of liquid stabilization, further enhancing the turntable's flawless audio reproduction.
Magnezar's automatic clamping system secures both the center and periphery of the vinyl, guaranteeing optimal playback quality. Additionally, the turntable can accommodate two tonearms including support for Klaudio’s tangential tonearm and laser pod.
Technical Specifications
• Wow and Flutter: 0.015% max
• Speed Accuracy: ~0.01%
• Motor Torque: 5Nm/sec
• Total weight: 121lbs (55kg)
• Footprint: 17.7 x 22.6 x 11in (415x575x280mm)
• Platter Weight: 44lbs (20kg)
• Platter Size: 14.4 x 4.1in (365x105mm)
www.klaudio.com
