the answer to what question please?Ok, the answer is no…unless you apply DSP.
ARe Bionors time coherent...the answer is no.the answer to what question please?
A speaker can only be time coherent if both the phase and physical spacing are correct. if either of those is not right then the speaker will not be time coherent.Theoretically they are Kugelwellenhorns, patented for having a large phase coherent 'plug'
A calculated phase coherent speaker IMHO always sounds worse than a speaker that is physically time adjusted..call me silly but that is my preference and that of many who have heard the difference so far.
Aries Cerat came closest to doing that with the Aurora, the tweeter was aligned quite well but not perfect (and the volume was WAY over the top at the demo)
Edit: Or DSP is used to correct both phase and distance digitally.
Electrical phase and physical alignment. If the electrical phase is correct then you adjust the driver distances such that the impulse of each driver reaches the ear at the same time. A step response tells the whole story of what is and what is not time coherent.You need to define your terminologies a bit more , moving physically is adjusting phase , so when you mention phase are you talking electrically or acoustically ..?
great question, I always think that great composers (and conductors) play with that aspect......given the size of the stage and the distribution of the musicians on the stage (L-R and F-B) is a large orchestra time-coherent to the audience?
isn't that exactly what I wrote?It is a compression driver that is essentially a big tweeter.
A theater has nothing to do with horizontal alignment choice "compensation". Aiming it some is a price of the directivity vs theater shape.
Dogma is not preserved here.
Is it? From what I've read, it doesn't go above 8K. Wouldn't you call that a midrange compression driver?It is a compression driver that is essentially a big tweeter.
The one critique that I've consistently heard for two way vintage horns is that they lack top end "sparkle." I have listened to my three way JBL Hartsfields with the 076 horn tweeter disconnected, you lose a lot of fidelity.
Bionor/Eurodyn crossovers are 2nd order. As in phase of the tweeter is 180* out of phase with the woofers. They are also not physically aligned.
All these assertions are wishful thinking. You are just lucky that some speakers support it enough to give you something to talk about. The reality is things are more complicated and design of a speaker is not that straight forward to make it good.
