ICOREM
18
2
135
Anyone swapped on a RONT II the GZ34 tube (original or an upgraded one) with the new SS Gz34 and can share some thoughts ?
bonzo75
22,649
13,683
2,710
London
this looks good. comes with a lot of tonearm platforms, that if you don't require you can sell off and buy the tube supply instead and an arm.
Lagonda
3,515
4,825
1,255
Denmark
this looks good. comes with a lot of tonearm platforms, that if you don't require you can sell off and buy the tubes supply instead and an arm.
He is actually selling the tube supply separately.
christoph
4,689
4,075
825
Principality of Liechtenstein
Reactions: Lagonda
ICOREM
18
2
135
Did anyone bought this tube and compared to a tube GZ34 either stock or NOS ?
bonzo75
22,649
13,683
2,710
London
There are many references in this thread. Please do a search
Reactions: uber2
cbl117
9
1
10
41
I'm considering the purchase of a Bardo with the RoNt III. Is there any issue with placing the RoNt III next to the Bardo on the side furthest from the tonearm? I'm trying to keep everything on the same shelf if possible.
defride
309
200
1,185
The system is sensitive to placement. I've an Oasis (Bardo in plinth) and initially wanted to place my RoNt II underneath with only a this shelf between, got very bad hum. Moved it to the side and a shelf below on the side further from the tonearm and no problem.
Can't remember ever seeing a RoNt on the same level as the TT in a system I've heard, that includes Brinkmann setups at shows.
Hard to say how it would work in your implementation. Would reach out to Brinkmann, they're helpful and usually quick to respond.
Reactions: DetroitVinylRob
cbl117
9
1
10
41
Thanks for that info. It aligns with what Brinkmann recommended this morning. I’ll need to see about moving the power supply to the side of my racks.
cbl117
9
1
10
41
Can anyone confirm if the Brinkmann ground connection at the back of the turntable (Taurus in this case) is a standard size banana plug connection? Thanks in advance!
