May I ask where you got the turnbuckles made? I also use turnbuckles but don't have the best implementation currently.
I assembled the turnbuckles: Bodies from Johnson Marine, right and left hand stainless all-thread, locknuts and pushrod ends from Industrial supply like McMaster-Carr. Also, because of limited rotation of the pushrod ends all connection points need to be set at angles to keep things from binding. Modelling in CAD is important for this.May I ask where you got the turnbuckles made?
Interesting thread.
My first exposure to field coil drivers was with RCA 1428B drivers on RCA multi-cell horns around 2000. Even in a mismatched system kludged together the RCA drivers produced the most effortless and natural midrange I had ever heard. This was at the home of the late Steve Steve Schell who was an encyclopedia of audio history and became the instigating force behind the limited production Cogent field coil drivers. During the '00s and teens I worked with Cogent to produce a few systems.
But still so many people are stuck with typical 15" midbass–usually ported–and a compression midrange and some tweeter. While there will be significant gains over permanent magnet drivers such systems still have many longstanding limitations built into the designs.
Where Cogent went one better was the design of their DS-1448 midbass drivers. With compression midbass giving high output down into the 70-80Hz range the transparency and transient response dramatically improves. Distortion is greatly reduced and the presentation becomes even more life-like.
And not content with just that in my own installation I built in bass horns. Originally 30Hz flares that put out ~106db w/m, when I reconfigured my space for the Cogent arrays I added so eq for a solid 20hz.
The main arrays are Cogent DS 1448 and 1428 field coils and Fostex T-925a tweeters driven with Western Electric 300B amps tweaked for me by Cy Brenneman. The bass horns are driven with VTL MB-125 mono amps. So it's all horn loaded and yet when listening there is no sensation of the mass of equipment producing the sound.
I got pretty lucky with the implementation. Oh, and I cannot overstate the impact of effective room treatment on the system: a good room can make mediocre equipment sound far better while a poorly treated room can make the best equipment unlistenable.
eso
(It’s surprising and embarrassing how few very high end speaker manufacturers use field coils…but that’s a different topic.)
The base design is from Bill Woods. Bill provided the basic design used by both Cogent on the West Coast and ΩMA on the East Coast.
Cogent principal Rich Drysdale and I devised what we felt was a cleaner connection between the drivers and horns that eliminated Bill's throat castings. Those castings limit the thickness of the wood sides and I wanted thicker material for a better visual balance. After experimenting with the basic design of Bill's I shortened the mid horns a couple inches while maintaining the mouth diameter. This increased the internal angle of the horns and makes a better match with the internal phase plug geometry.
The 1448 are on the truncated midbass as designed by Bill Woods. The networks use a 1st low pass at ~350Hz if I recall. The Mids are a simple 1st order high pass as are the tweeters. In my system the networks use charge-coupled capacitors and the inductor for the low pass is a custom wound 10Ga coil with negligible insertion losses due to the large gauge wire.
I've been seeing your speakers posted in several groups on Facebook during the past week.This is very interesting and a beautiful build, @ArtisanalAudio, congratulations!
Are those Bill Woods Conical horns?
I would love to see more photos of the speakers, especially the frame and how the drivers are attached to it.
Looks like you are using an active crossover?
Can I ask how you have implemented the 1448 and 1428 drivers? What are the differences?
“My first exposure to field coil drivers was with RCA 1428B drivers on RCA multi-cell horns around 2000. Even in a mismatched system kludged together the RCA drivers produced the most effortless and natural midrange I had ever heard.”
I am biased, but I agree that the RCA1428/1443 on a conical horn has unmatched midrange tone and realism. I auditioned the Wilson Chronosonic XVX (with the intent to purchase for a second system) and they did not achieve the same level of realism in the midrange.
I got quite lucky with my setup, using the Fostex T500aMkII and Supravox FC woofers in the upper bass, and a transmission line active sub, I have flat (+/-5db) response in my room from 20Hz to 20K. Not that frequency response defines a world-class system, but it’s a good foundation.
The Duelund CAST crossover has made a big difference, in addition to room treatment and vibration control and AC and ground filtering for the FC field coil power supply. The PSU itself also makes a tremendous difference - the magnetic field is in the signal path, after all.
Interesting... thanks for sending. One would think they should have asked me for permission to repost!I've been seeing your speakers posted in several groups on Facebook during the past week.
Kind of a curious coincidence. It looks like this page posted the picture and several others shared it:
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
