General Question about Belt Drive Turntables
Lagonda
3,515
4,825
1,255
Denmark
Kevlar might have higher resonance, which might be bad
Its not full kevlar, just enforced with some strands, i haven't tried mine yet, i like the sound of the Origin Live belt i use, but be careful when adjusting the motor position with you hair to close. I almost ended up looking like Kojak, luckily i had a pair of scissors close by or i would have starved to death. Broke the new belt and had to order a new one. :eek: IMG_2516.png
PeterA
12,669
10,942
3,515
USA
Peter it is probably similar to the kevlar enforced thread you got from David. :) Same philosophy and identical not ! View attachment 125521
Milan, the knot looks different. There is an extra twist. I have not yet tried ddk’s thread in the longer length. I’m simply trying standard sewing thread initially. It is very thin.
Doc76
44
28
18
63
United States
Its not full kevlar, just enforced with some strands, i haven't tried mine yet, i like the sound of the Origin Live belt i use, but be careful when adjusting the motor position with you hair to close. I almost ended up looking like Kojak, luckily i had a pair of scissors close by or i would have starved to death. Broke the new belt and had to order a new one. :eek: View attachment 125523
Is that the new album by the rock band Hair? :p
Reactions: Lagonda
DasguteOhr
2,447
2,625
645
Germany
Have you ever tried a chrome leather belt?. you're probably asking why. It has been used for machine drives for over 100 years. avantage no skip & slip effect from rubber belts. buy this one in the link. Take it to the shoemaker, have it cut width and length and sew the ends zig zag stiching by him. Then you report here how it sounds.
DasguteOhr
2,447
2,625
645
Germany
Frankfurter knot aka weaver knot
the sound of Tao
3,641
4,896
940
Ouch, that looks seriously savage Milan… thank heavens it’s not your groin hair. You might need an analogue health and safety hair net when working on your tt… still a better look though than wearing a whole of head safety tin foil cap when working with digital dongles :eek:
Reactions: Bobvin and Lagonda
Lagonda
3,515
4,825
1,255
Denmark
I am a belt drive lover, but my groin is never close to the motor/belt ! ;)
thekong
254
146
948
@PeterA , @christensenleif@msn.com , Hi Peter, Lief, I also prefer inelastic belt / string, and using a Mylar belt on my Rockport Sirius II.
However, I have always had this question on the back on my mind regarding the Micro Seiki or similar strings. Since you have to tie a knot with these strings, there must be some sort of a bump when the knot goes through the pulley. I am pretty sure it is inaudible, but did you guys ever check it with instruments, or programs like the AnalogMagik , to see if it showed up in the measurements?
Another question for both of you is about the arrangement of the motor pot. As mentioned by @Salectric , many Platine Verdier users like to place the motor on a separate rack, yet Thom of Galibier was totally against it when I communicated with him many years ago, stating that if the motor pot is on a separate rack, then the floor vibration may cause the two racks to move slightly differently, causing a microscopic change in distance between the TT and motor, a change in belt tension, then a change in TT speed. That sounded quite logical to me!
Peter, in your case, while the TT and motor pot are on separate steel slabs, they all sit on the same rack top. So, in my eyes, they are still in some ways hard coupled together.
So my question to both Peter and Lief is whether you guys have tried putting the TT and motor on totally separate racks, and if so, do you hear any detrimental effect with this arrangement?
Thanks
mtemur
1,413
1,362
245
48
Sorry, I jumped in but knot on the string is both audible and measurable. AM and other ios apps do detect slight deviation. I know it very well from my La Platine Verdier. Of course that doesn’t mean string sounds bad. IMHO it’s best to use a silk string without a knot like the one used on Kondo Ginga.
PeterA
12,669
10,942
3,515
USA
Hello thekong,
I do not hear any effect from the knot. It might be because of the loose thread tension, but I am not sure. I have not tried placing my motor unit on a separate rack. The two separate steel plates use different kinds of isolation underneath them. They are very stable but separate and now further apart. The steel plate between them supporting the control unit of the phono stage also serves to damp the top shelf of the rack.
These efforts are all matters of degree. Separate top shelves on the same rack would be another approach and perhaps the next step.
Reactions: thekong
thekong
254
146
948
Hello thekong,
Thanks Peter! I have never thought of separate top shelves on the same rack, certainly something to try !
thekong
254
146
948
Hi mtemur, thanks for the reply! I have no experience with the Kondo’s silk string, no knot is certainly great, is it custom made? Any idea where I can get some to try?
Thanks
Reactions: mtemur
mtemur
1,413
1,362
245
48
Thanks
I’m sure it’s custom made for Kondo but I doubt that it’s sold separately. Maybe it can be bought directly from the supplier. IMHO it’s worth to ask local Kondo dealer.
Reactions: thekong
