General Question about Belt Drive Turntables
Jan 18, 2012
2,373
2,476
1,475
Drobak Norway
My Melco plinth is placed on a separate marine MDF slab that is placed on 200Kg sorbothane pucks on a 70mm African mahogany top shelf in the rack
The motor unit is placed directly on same mahogany top shelf
reg the knot; I can feel it with my fingertip on the outside of the thread, but not on the inside IMG_1692.JPG
Reactions: PeterA and thekong
thekong
254
146
948
Jan 18, 2012
2,373
2,476
1,475
Drobak Norway
btw when I had tt in living room I had motor assy on top of separate VPI rack and plinth on other.....couldn´t detect any results from assymmetrical movements in separate racks
but sonic profit from getting all sources and most of the electronics into adjacent separate machine room was dramatic
Reactions: Lagonda and thekong
Bobvin
1,720
3,078
665
Portland
www.purewatersystems.com
I served on board of Guppy IIA, Tang, Type209 and Type209 Mod1400 class submarines.
Now there is a thread tangent I never expected!
bonzo75
22,650
13,685
2,710
London
You do get the background though - They got so used to sitting in enclosed chamber using a sonic radar, listening to the same echo of the same sonic signal - so you can see how that experience translates to get them where they currently are.
Bobvin
1,720
3,078
665
Portland
Tone deaf?
Massimo66
118
126
50
57
Thanks Peter! I have never thought of separate top shelves on the same rack, certainly something to try !
Hello the kong. I use this solution. on a solid tech table I replaced the last shelf with a 2.2 cm sheet of marine MDF. Above this I positioned a first 3 cm slab of marble then a 4 mm sheet of industrial rubber and on top of yet another 3 cm marble slab the last marble slab is cut with the final U-shaped part and the marble obtained from the U cut I had smoothed to 1 mm on each side in order to physically separate it from the rest of the slab and on this I positioned the motor unit of my VPI HR X. and the result is remarkable with a considerable increase in the dark background
Reactions: thekong
Lagonda
3,515
4,827
1,255
Denmark
Just getting sources and speakers of the same floor helps a lot, mine are actually on 2 separate parts of the foundation and absolutely no connecting wood flooring.
Lagonda
3,515
4,827
1,255
Denmark
Yes it can be hard to keep the periscope on target at all times in some of the threads ! o_O
