Kuzma 4 point
Hi, Rockitman,
Yes that is correct- that is the reason why is there a wire loop.
Hi Franc!
Welcome to WBF!
Maybe we can start another thread and you can talk a little about your new cartridges?
Hi,
Thank you and I would be glad to join some of the debates.
Just to add an extra information in debate about the differences between 4Point and Stogi Ref 313 VTA tone arms.
In Stogi Ref 313VTA tone arms we use best available steel ball bearings. In tone arms supplied since March 2012 we started using ceramic ball bearings. These have lower noise floor and lower starting friction- thus improving performance of this arm. This change was revealed in July 2012.
Welcome Franc!
This is a great board. You'll enjoy reading and posting here.
Hi,
being a designer of Kuzma 4Point tonearm I would like to clarify confusion regarding how is done wire loop on this tonearm.
Photo on post #52 is correct: All 4Point tonearms always had big wire loop in this position when tonearm is set up for use.
Tonearm 4Point does not have detachable cable so during transport cable is secured on small pin on armwand with tube to avoid any forces on thin wire loop.
Thus makes it easy and safe to handle during transport and mounting. But after you insert armwand with tube onto bearing, you release screw which holds black metal cable holder on pin and reposition it on second pin which is on VTA tower support.
Welcome to WBF Franc. Thanks for clearing that up. That is a smart way to protect the wiring during initial setup.
Looks like a very well designed arm. Hope to give it a listen in the future.
Hi Franc, and welcome. It will be interesting to hear people's reactions to the CAR-50 cartridge coming this week, being mounted on the 4Point for demo. One is sold...
Hi!
Is there any first hand experience with both 4Point and Triplanar MKVII?
I currently own a Triplanar but i´m considering replacing it with a 4Point.
Is the 4Point a "faster" and more "in your face" tonearm than the Triplanar?
Hi!
I lived with the Kuzma Stabi Reference/Triplanar VII/Benz LP-S and Kuzma XL4/Triplanar VII/LP-S combination for years. Triplanar is a great tonearm, no doubt about that but 4Point is simply in a different league - on a much higher level. Triplanar can not touch 4Point in ANY sonic (or any other) department! OK, you may consider it visually more attractive if you will ;) but in comparison to 4Point it sounds obsolete, slow and thin and no, 4Point is does not sound "in your face" per se. If a recording is in your face, well, 4Point will reveal that. It has much less character than Triplanar. Please read Fremer's review in Stereophile. I agree with everything he said.
I lived with the Kuzma Stabi Reference/Triplanar VII/Benz LP-S and Kuzma XL4/Triplanar VII/LP-S combination for years. Triplanar is a great tonearm, no doubt about that but 4Point is simply in a different league - on a much higher level. Triplanar can not touch 4Point in ANY sonic (or any other) department! OK, you may consider it more attractive if you will ;) but in comparison to 4Point it sounds obsolete, slow and thin and no, 4Point is does not sound "in your face" per se. If a recording is in your face, well, 4Point will reveal that. It has much less character than Triplanar. Please read Fremer's review in Stereophile. I agree with everything he said.
Welcome Franc--I've spoken to you at the shows and enjoy your products--and know Scotty M also--kudos to your products--yes as noted I agree totally with the comments re the 4Point--it is in my observations sonically purer to the Triplanar/ Graham /etc--even Mr.Fremer says so over the latter!
Incidentally would love to hear a Techdas AF1 and 2 with the Kuzma 4point rather than the Graham--that would be something.
Good Listening
BruceD
Hi!
The TriPlanar is a fine arm which tends toward the warm side. The mid bass is a bit overdone, and with a cartridge which is already heavy in that area it can be too much. The highs are a bit rolled off. The 4Point is more neutral across the spectrum, more detailed and dynamic but not in-your-face.
Interesting what you say about the bass. It is well known that Kuzma Stabi Reference/Triplanar Vll is "a match made in heaven". Years ago we also made a direct comparison between Kuzma Stabi Reference/Triplanar Vll and Kuzma Stabi Reference/4Point combinations, both with Benz LP. Well, improvements weren't that great considering a HUGE difference on the other side when I substituted Triplanar for 4Point on my XL4 turntable. I was simply shocked at the improvement it made, most notably in the bass region where Triplanar was weak and thin and all other aspects of reproduction were greatly improved too as I indicated earlier. So, obviously the turntable pays a major role how extensive improvements the 4Point will bring to the sound.
Thank you all for your kind replies! Really a positive and interesting forum this....!
I currently own one Triplanar MKVII, One SME IV.iv and one Kuzma Stogi.
You guys just made me order a 4point as well! Hopefully it won't take more than a week for it to arrive.
My vdh Colibri docent work as well in the Triplanar arm, its to soft i suppose. So that one will most definitively do its job in the 4point.
Will try out my friends Dynavector XV-1s in the Triplanar and I'm hoping for a better result.
My SME IV is just pure enjoyment with the Grasshopper XGP. Smooth and warm. So that will stay as it is.
Thanks guys, you just costed me a lot of money :p
I spoke only of the TriPlanar's mid bass. As you know, the 4Point's bass is remarkable, and the arm acquits itself very well on a wide range of turntables, including the Stabi Reference.
Well now, it seems i will need them both. They are truly wonderful, and has both ups and downs imho.
Nice Vermin. Congrats.
The Kuzma 4point goes into editing after the Onedof table. Also, the Kuzma is having an addendum shoot on the excellent Triangle Art Signature. This table is on the efficient frontier...
Interesting, reminds me of my days at UChicago
Anyone knows what is the current US retail for Kuzma XL4 with single arm base, PSU and 4 point arm with silver wiring ?
I tried http://eliteavdist.com/contact.cfm but their contact form is not working.
Since you are in Poland you should contact the distributor there, listed on the Kuzma website. Prices may vary from region to region, so US prices may not be relevant.
Just trying to learn the US retail, thanks.
Let's just say it's between 35 and 40k and leave it at that. How is it relevant? People who buy systems at this level are not focusing so much on the price tag. They buy them because they provide immense listening pleasure and are thoughtfully designed and made to deliver consistently excellent and reliable performance for many years, and they tend to consider such a purchase a final one. A big Kuzma is not a stepping stone.
