Ok i will enlighten you its fairly simpleWhat exactly is “BS”? Enlighten me on what factors I should consider important!
BS means Bullsh***t
You know what is BS?Ok i will enlighten you its fairly simple
BS means Bullsh***t![]()
Because the compromises we are discussing are not subtle. Time alignment, or lack of driver rigidity is akin to saying G6 wings are not perfectly aligned for level flight!
Both brands should have done better for what they are charging.
Ultimately, these are boxes with magnets and paper...
Selling a $750K speaker with non time aligned drivers. This isn’t rocket science brother!
Let’s go back to basics:
Sound Science 101
The original source of an instrument the speaker is trying to reproduce does not originate for multiple drivers. So when you split up that source into multiple drivers, you better make sure that the phase and time delay across all drivers is aligned - certainly at this price point.
I wouldn’t accept a plane with a bent wing, because it’s easier to build that way. I guess you would.
I am not. The facts are the facts. You can choose to ignore them or to not care about them; but you cannot argue that reproducing a single point source of sound among multiple drivers that produce sound at different time intervals is FAR from ideal. When it’s a $10k speaker, sure, compromises need to be made. But at $750K?! Come on. That’s lazy engineering.No it is not. Please do not mix physics and engineering with perceptual science and its methods and outcomes.
I agree with you there.I buy what i think sounds good , its not very complicated
You 100% can hear time alignment. Get real. Audition a speaker that has adjustable time alignment and you decide if you can hear changes made to driver positions. Ask a Wilson dealer to do this.
No papercones,i bet the cones come from here . all big companies let build there.You should stop reading Lee s reviews .
Good sound has as much to do with NASA technology ( some carbon lol ? ) , then a pigeon in my garden
Ps magico doesn t uses paper cones .
If were going the Carbon / " High tech " gives good sound route , there are numerous other possibilties you can buy with great sound , Mclaren 720S great sound V8 only 200 K , and it actually gets you somewhere
With the 750k budget you should be able to get M6 plus the restThis is off topic but i would use the 750 K and "invest " it in a magico S5 mk1 or 2 or a V3 even and buy top amplification plus a Wadax .
If it was my own money.
Speakertech is stagnating imv
Yes. 100%Speakertech is stagnating imv
Yes. 100%
Every high end speaker should use field coils for one thing. Superior in every way, other than cost.
Dcathro have you detailed your mods to the phalanx somewhere.. a lot of mid drivers to upgrade !Most people would not want the hassle of the power supplies. Imagine a FC Wilson XVX with a power supply for every driver
The no compromise approach can be applied in a lot of other aspects. For example Mike Devore makes his top driver baskets and wave guides from Bronze - does this mean that my FC drivers with Aluminium baskets are shit?
Are Aluminum cabinets better than wood? Maybe Copper or Silver would be better still. What should all high end speaker cabinets be made from?
What about the cabling and crossover parts?
Whatever anyone uses or does, there is always going to be something that might be better.
