Retina display for the iPhone?
Ray Soneira
14
Amherst NH USA
www.linkedin.com
The iPhone 4 has an outstanding display... and I'm glad that Apple resisted the emotional rush to OLEDs because they still need lots of improvement before they will be ready to compete with the highly refined IPS LCDs. The iPhone 4 display should be comparable to the outstanding IPS LCD in the Motorola Droid, which I tested and compared to the Nexus One OLED, which was trounced by the Droid...
http://www.displaymate.com/Nexus_Droid_ShootOut.htm
Steve Jobs claimed that the iPhone 4 has a resolution higher than the Retina - that's not right:
1. The resolution of the retina is in angular measure - it's 50 Cycles Per Degree. A cycle is a line pair, which is two pixels, so the angular resolution of the retina is 0.6 arc minutes per pixel.
2. So, if you hold an iPhone at the typical 12 inches from your eyes that works out to 477 pixels per inch. At 8 inches it's 716 ppi. You have to hold it out 18 inches before it falls to 318 ppi. The iPhone 4 display resolution is 326 ppi.
So the iPhone has significantly lower resolution than the retina. It actually needs a resolution significantly higher than the retina in order to deliver an image that appears perfect to the retina.
It's a great display, most likely the best mobile display in production (and I can't wait to test it) but this is another example of spec exaggeration.
http://www.maximumpc.com/article/features/display_myths_shattered
Nice read Ray
Thanks
