Various DAC Audition Impressions
Kingrex
2,949
2,425
350
I am finding there are a couple Memory Players out there. I have no idea if they are built on crap parts and sound like crap, or decent parts and play well. A $27K player is not affordable to me.
Alrainbow
3,260
1,431
450
LAUFER is the real one I’ve heard it at shows
now for me it’s not the sound I like.
it’s a quality product for sure like hq player
One must enjoy the sound over all.
it’s really based on science of time in the bit stream
any given cd player used as a transport has its own sound for many reasons.
the better ones seem to be more dynamic less noise but still not the same.
AL M uses a spidif reclocker I do as well it truly levels the playing field on cd transports but still they have a variance.
emyyl
6
3
3
60
As your Mojo server and DAC are both really high quality, my guess is that you won’t find substantial difference between the CD transport and your server.
You might find more improvement through switches, renderers and reclockers to replace the SPDIF connection. Cost about $5k in total for me but I get a more 3 dimensional sound, bigger soundstage and better decay and timing. The Audiophilestyle forum has lots of pointers on this.
Kingrex
2,949
2,425
350
I have 3 independent LPS feeding my modem, router and Linear Solution switch. All 3 feed by a Torus isolation transformer. I have Blue Jeans CAT 6 througout. I have an Intona Ref USB cable.
I have tried 2 different Endpoints. I could not hear a difference. I tried an Intona USB device. No change. I tried 2 different ethernet filters. Gigafoil and some other audiophile one. Both made if hifi(fake) sounding.
Mojo Audio told me to get the Jays. Said its worlds better. No comparison.
I have also been looking at a Grimm MU1. But I don't have $12k to try.
Kingrex
2,949
2,425
350
I agree. Everything has a sound. It sounds like the Laufer is sort of "slick" sounding. Smoothed over with a loss of dynamic snap. I like snap.
Reactions: Alrainbow
emyyl
6
3
3
60
Looks like you’ve done the switches etc. In my case I swapped out the Blue Jeans Cat 6 for Sablon. More body, impact and air.
i read that the Grimm’s prefer the EBS/XLR output.
Sounds like your heart is set on the CD Transport. Would be interested to hear your findings.
Reactions: Sablon Audio
Kingrex
2,949
2,425
350
I also have a AQ Cinnamon ethernet. It changes the sound a little.
Honestly, I will probably do nothing. There are other area I would prefer to place expenses. Such as getting my amp situation worked out.
Cybermaggies
26
18
68
52
Federal Way, WA
Are you using stock DC cables going from the LPS to the modem, router, and switch? I am powering all three devices with LPS's as well and upgraded to silver DC cables. The magnitude of improvement was almost as significant as adding the LPS itself.
Kingrex
2,949
2,425
350
Stock. I do appreciate a good cable. Where did you get yours. I looked at some Gent cables a few years back. Never got one. I also use a Ifi power supply for the Modem so there is no options there. The Linear Solution switch came with a half decent cable.
Cybermaggies
26
18
68
52
Federal Way, WA
I ended up building my own. I did try a Farad Level 2 Silver, a Ghent with Neotech 16awg solid copper and made several versions using stranded and solid copper, but my solid silver easily surpassed them.
If you stream, I think you will find putting a Farad with a quality AC & DC cable or its equivalent on the modem will yield the most improvement vs the switch or router.
Kingrex
2,949
2,425
350
I heard the biggest improvement with the switch. I also heard an immediate notable improvement when I bought a separate router from the modem. The power supplies were smaller gains but worthwhile. But that is just me in one system. There are lots of great threads where people have tired all sorts of configurations.
Kingrex
2,949
2,425
350
What gauge silver did you use?
What did you wrap it with?
Cybermaggies
26
18
68
52
Federal Way, WA
Kingrex
2,949
2,425
350
I have had my Mojo Audio DAC running pretty continuously for over a week. I was out of town with a loop of music to my pre which was also on. I got home last night. I fired up the amp today and had a few moments to listen. For the first time in a long time I wanted to flip off the vinyl and put the digital back on as I was enjoying it that much. There is nothing in my dogital now that would tell me I am playing a streamed file vs a record. I am totally satisfied with my digital source. Whats scarry is Ben aith Mojo is adamant I am only getting a taste of what I could be if I were to put a Jays Audio CD3 MK3 as a source to the DAC. He should know. He made my server and DAC. And owns the Jays. N
charles1dad
451
576
330
69
Michigan, USA.
Ben at Mojo is wise. I’d heed his “adamant “ recommendation for a high quality CD transport.
Charles
