In the afternoon I have decided to continue to try a few of the tubes I was able to recover and measure from the bulk packs. This time I chose something totally different to both Valvo E81CC and Siemens E81CC, which both sounded nice and close to my preferences: an old D-getter Tung-Sol 12AT7.
This tube measured terrible (a little bit above 50%, so around 5mA for 250Va, -2Vg1) but since it is quite unique in my collection (I do not have other Tung Sol ECC81/82/83) I wanted to try it.
It has a small hum from the start, and the overall sound is more tubey, less detail and a more forgiving tubey sound. Not bad, from time to time, and a good contrast to what previous tries provided. I also have around a RCA one, rectangle getter, that one maybe in another day.
And since my previous investigation ended, I will start a new one:
This is another mistery tube, another ECC81, this one measuring quite good, above 80% on both sections. No date codes, just "RIO" and 2854 which might be the 28th week of 1954. In rest, rectangle getter fixed without rod, directly on mica. The mica from the bottom seems transparent. Searching for "RIO ECC81" brought me to an
old radio which seems to be produced in Germany. What to say, seems a nice tube, black plates as many into audio like. In my case the color of the plate, shape of the getter or color of the base have no effect on audio quality but might be a mark of the age of the tube, and usually older tubes sound better to my ears, with a few exceptions.
I'll try to find out how the mistery "RIO" ECC81 sounds, and also try to decypher its origins.
Later edit: It seems the Tung-Sol 12AT7 started to raise a little bit the emission above 60% after some hours of usage, maybe the time I kept it on the tester was not enough, for such an old tube stored for decades. I'll measure this one again in my next measuring session. Unfortunately the hum remains, but it is low volume, barely hearable between tracks.
PS. My instinct tells me the mistery ECC81 is british made, those black plates, those round holes in mica remind me of GEC. But of course, I might be wrong.
