The point being in context of signal level Xiph; specifically low level signal.
I knew what you meant, it was just ambiguously worded. There are who think that the absolute level increases a signal level decreases, when it's _proportionately_ greater for a low level signal, just like tape hiss is proportionately greater for a low level signal on tape. (I'm thinking aloud to third parties here, not you Orb
That said, the stair-case is noticably different in terms of transfer function and undithered output relating 16-bit to 24-bit so depends the context of approximately constant as well
Sure. The specific harmonic products are the same, but the amplitudes and phases of the products relative to one another change.
Only discussing from a technical standpoint not that music output from a DAC is "stair-case" as I agree it is not (although again technically there are 3 different aspects to stair-case, quantization, ZOH, aliasing), but I am concerned how some are using such points to say "staircase does not exist" when in terms of EE and the various stages it does in specific context
It exists as an implementation detail in DACs, however even in the vast majority of those DACs it is not a ZOH of the input PCM. I understand what you're saying, but I'd suggest '
a staircase exists at some point in most implementations' is the accurate statement (and an important one), and '
the staircase exists at some point' is inaccurate. It would be like saying that oversampling is an inherent, essential property of PCM when it is not-- it is merely an important engineering concept in practice.
A DSP engineer who thinks of digital waveforms as inherently staircase-like will find himself in mathematical trouble (the kind with real-world implications) rather quickly. But you're absolutely right that any DAC engineer would realize the ZOH is a critical tool.
So, again, no argument with your essential point, which is entirely correct. I'm only debating the wording of the specific nuance.
Edit:
I do feel it would be nice if your site included a presentation and comparison for say a loud and quiet signal (few LSB in amplitude) for the 1khz tone and for both dithered/undithered and went a bit more into detail about quantisation/transfer function and the bit amplitude relating to different level signals, and also 16-bit and 24-bit example and why 24-bit sinewave is better in this context but with dither considered not critical (same applies to low level signal and dither).
I played with the idea of making a little javascript dither playground tool for the website, but it would eb kind of boring. The vid did show a low vs high amplitude sinewave without dither. With dither it's unremarkable... the noise floor just stays static.
