BTW, all the "accusations" about Swenson not having any measuring gear is exposed here:
And an addendum here:
Furthermore he goes on to give a short tutorial in using scope probes
"I don't have fancy pictures so ya'all will have to look them up on the web.
Tektronix 2467B scope -- 400MHz, 4 channel. $600 on ebay, $13K originally
HP 3585A spectrum analyzer -- 10Hz to 40MHz 3Hz bandwidth. $900 on ebay originally $32K
DS800C 4GHz sampling scope (USB to computer for display), great for some things, useless for others, but only $800 new.
Generic Multi-meter (from Sears actually) used to have much higher street cred ones, but they are all gone now, this $13 meter has lasted through decades of hard use, and honestly does just as good as the "big boys" for most use.
Pair of Earthworks QTC-1 mics, 9Hz to 40KHz +- .5dB
I also have a Tektronix 2246 scope (100MHz 4 channel) which I bought brand new 30 years ago for $2200 when I got my first job out of college and had some real money to spend. These are available for ridiculously low prices on ebay. (I saw one for $97 that said it was working!)
I also have two small Tektronix analog scopes that I picked up for $35 for both at a yard sale. I don't use them in the lab but they are great when doing some remote debugging.
If someone wants to start out getting a scope I personally would get the used 2246 (as long as it really works) rather than one of the cheap digital scopes on the market today.
I don't have time to go over it now, but probes are very important to get right for your scope. I might give a little mini tutorial tomorrow if I have time.
I'm in the process of building two very important pieces of test equipment, because they are insanely expensive to buy them.
Phase noise measuring setup, should cost about $1k to build, and do better than the $170K commercial ones.
Very low jitter sampling system (ADC). Looking at two different versions, one does 24bit at 1MHz sampling, the other is 16 bit at 250MHz sampling. The 1MHz will have a sample jitter in the 150 fs range, the 250MHz one will be in the 300 fs range. Both store data internally then download to a computer for analysis.
John S."
I forgot two more:
Intronix Logicport 34 channel logic analyzer. It connects over USB for display. Very useful for digital analysis. A pain to setup, all my recent stuff is dense SMD stuff, I have to glue a pin header onto the board and solder thin little wires onto the chips (not easy for 0.5mm pitch chips), but when nothing else can do, it is well worth it.
LeCroy Mercury T2 USB protocol analyzer. It can be quite useful when a USB interface is not working right, but it is a pain in the neck to pour over huge packet logs trying to find where something went wrong.
John S.
