By definition.I think certainly that once music is converted from analog to digital at any stage it is immutably digital thereafter.
Interesting, but could other factors be at play? For example, as I recall, UHQR LPs are pressed on 200g vinyl which is thicker than 180g pressings. Did anyone try raising the VTA ever so slightly to see if that improved the sound of the LP?I think we all preferred MadFloyd's digital file of Kind of Blue last week in his system over the vinyl reissue, not because of anything inherent in the digital, but rather because we did not like the mastering of the recent UHQR release. I think we all preferred the early pressing on vinyl as sounding the best that day. This speaks to the earlier points about the mastering and recording being primary.
LOL, what record stores, the 2 per city? Compared to digital it's a blip of total music sales at ~5%. There's no significant comeback, it only seems so from an audiophile vinyl lovers' perspective.You are incorrect. Go to record store day, huge lines of millennials buying records. The age bracket of 25-35 is more likely to buy records than the boomers:
Vinyl buyers in the U.S. by age 2019| Statista
Consumers in the age bracket 25 to 34 were just as likely as those aged 55 and older to buy vinyl records in the United States, with ** percent of those in both age groups having purchased at least one record in 2019.www.statista.com
And to the contrary - digital has launched forward doubling annual revenue from ~$6 Billion to ~$12 Billion over the past 10 years. The populous is indeed re - discovering and enjoying music, it's called digital steaming.
U.S. Sales Database - RIAA
I have the original Columbia 6-eye(no CBS at 12'o clock), and it bests my 4 single-sided Classic 45 rpm reissue. This saved me from buying the prone to pressing defect "clear" UHQR.Yes, there were likely many factors at play. We did not have the time or interest in investigating all of them, or even discussing them beyond the likely differences in mastering. We did not raise the arm slightly. There just seemed more information on the earlier pressing, which was stripped/absent on the reissue. Low level resolution, nuance, and ambience. Bass quality too, as I recall. We did prefer one digital file to the UHQR also which I found surprising. So best was early vinyl, second best was digital, last was new vinyl. With more time, we could have experimented some.
If one prefers the heavier UHQR to an early, non original pressing or even to a later reissue, then to be fair, he might want adjust the VTA for the thinner LP too. Lots of possibilities as you point out. Thank you.
I just went to St Louis, MO and there were 15 stores that came up on my search. In LA and New York there are 50+ places that sell vinyl. This is an audiophile website and we are talking about audiophile behavior, not the general public. When you're discussing premium boutique wine, do you mention boxed white zinfandel outsells Opus One? Ridiculous.
*If* this discussion is / was about vinyl vs digital then its a discussion of storage and playback. In my opinion a good way to compare this is to compare modern digital--master based vinyl to the released digital file. Sure it isn't 'AAA' analog but you can compare playback ( which already contains too many variables ) without the confusion of recording and mastering differences.
Anyone with a home stereo system at this point is an audiophile. Remember, audiophile doesn’t mean it’s an expensive system, just that it’s a dedicated audio system. Go on Reddit and you’ll see that there are thousands of posters with really cool vintage systems with AR, Bose and IBL systems.Except that most vinyl buyers are not audiophiles, and buy into the digital vinyl experience with their turntables featuring USB ports.
So perhaps we are discussing boxed white zinfandel instead of Opus One premium boutique wine after all, when it comes to the broader vinyl resurgence.
This is a good point…with a vinyl system, the media is as important as the gear.What bothers me about the media is that good early pressings of jazz, classic rock, and classical titles is expensive to outrageous while digital music is basically dirt cheap to free.
Sadly, the supply of good original vinyl is scarce and the demand is high. I do not think this is going to change anytime soon and it is reflected in prices.
The cost of pursuing digital is in the hardware and software upgrades, not in the music.
you simply can’t compare digital downloads which are primarily listened on portable devices to vinyl sales. Comparing the two is absurd.
so maybe my boxed wine/Opus example is not accurate. It’s more like boxed wine/small boutique winery.
Sometimes it does. Mostly with the kinds of music not often used on wbf for listening references. I used to own a Neumann VMS70 cutting system so have had some hands on experience.Except that vinyl needs different mastering anyway, even when it is based on the released digital file.
Because of limitations of the vinyl format, the master needs to be modified, see for example:
Mastering For Vinyl Records | Gotta Groove Records
Tips for vinyl mastering - preparing digital masters for vinyl pressing.www.gottagrooverecords.com
I could pull up other websites that basically say the same thing. These things have been known for a long time.
This can also be verified by looking on Reddit audiophile type forums. Mostly young people with modest or beginner type systems, with turntables and a stack of vinyl. Great to see these younger folks being dedicated in the hobby and going vinyl..You are incorrect. Go to record store day, huge lines of millennials buying records. The age bracket of 25-35 is more likely to buy records than the boomers:
Sometimes?? No matter what it requires RIAA EQ as a minimum.Sometimes it does. Mostly with the kinds of music not often used on wbf for listening references. I used to own a Neumann VMS70 cutting system so have had some hands on experience.
Very much agree, but also Peter it’s worth noting the various outcomes of choice of platform to pursue recorded music has a range of potentials and constraints well beyond cost of hardware v software.What bothers me about the media is that good early pressings of jazz, classic rock, and classical titles is expensive to outrageous while digital music is basically dirt cheap to free.
You win on the # of records stores, however how many are open today versus, say 1972? I’d wager <50%. Net is - there’s no resurgence, it’s a niche market at best.I just went to St Louis, MO and there were 15 stores that came up on my search. In LA and New York there are 50+ places that sell vinyl. This is an audiophile website and we are talking about audiophile behavior, not the general public. When you're discussing premium boutique wine, do you mention boxed white zinfandel outsells Opus One? Ridiculous.
OK- good point. Most times people refer to 'different mastering' they refer to mastering techniques that address phase, LF, HF and limiting. Most mastering studios offer 'vinyl pre-masters' for this reason. RIAA is embedded into the cutting rack and not a mastering engineer decision. So perhaps this is a matter of semantics...Sometimes?? No matter what it requires RIAA EQ as a minimum.
Rob![]()
