Hello,
it appears that I have a problem with my 16pin connector, and I need some info on it.
I own a Cambridge audio azur 540c CD player (It has been around 10 years). Recently, it started to misbehave, and I did an inspection on it. I suspect a 16 pin cable connector which connects the laser with the system to be the cause. Here are some pictures:
Please give me some information about the numbers seen above. Do I need to search for the exact model to replace this cable?
Yes, I tried to correct the pins with some superglue - did not help.
Thank you
Thank you
