Cross posted from this thread:
Here's the graph showing the before and after of dallasjustice's speaker placement. The frequency resolution is 1/12th octave.
The placement shown was a result of the following:
1) analyzing the 'before' graph to identify root causes of the issues. In this case there is a room mode related peak at ~25Hz another at ~47Hz and a speaker boundary interference related null at ~37Hz. There is no modal support for frequencies between 25Hz and 47Hz which is another cause of the frequency response null or 'droop'. The room mode frequencies and distribution were calculated using a proprietary room mode calculator. In more complex non-rectangular rooms a boundary element model is used to predict modal frequencies and distribution.
2) determining suitable placement to minimize coupling of speakers to the room modes and minimizing speaker boundary interference. In this case we were lucky in that the null for the 47Hz mode was around 5ft from the back wall, the placement of the speakers in this null would also result in coincidence of the speaker boundary interference null (caused by the front wall behind the speakers) at this frequency, therefore further reducing its effects.
Blue is before, green is after.
All of this is before any room treatment. Acoustic treatment will help smooth the modal issues about ~60HZ. EQ will be used to further flatten things out below this. The real objective of this exercise was to set things up so that frequency response was as flat as possible below 60Hz so that acoustic treatment could deal with the remaining above 60Hz issues. It's obviously very difficult to EQ a null such as the 37Hz one, so that's why speaker placement is important, as this exercise shows.
