My room got the full treatment with devices from ASC (Acoustic Sciences Corp.). On these two system pages there are a few pictures of the room with tube traps, sound panels and window plugs:
http://www.whatsbestforum.com/showthread.php?17334-My-minimonitor-subwoofer-system/page2
Also the carpet behind the speakers helps (the profound effect of the window plugs is described on my system page 2).
Before I had any room treatment, and also no carpet behind the speakers, my soundstage had been very flat. Introducing tube traps and sound panels allowed for spatial depth for the first time. Yet at some point I had done some brief experimentation, and after all the other room treatment subsequently added there was now also spatial depth without the corner tube traps.
Recently I lent the stacks of four corner tube traps to a friend, and thought, well, there might be some effect of their absence, but the harm done should not be too great.
Oh my, was I mistaken!
Even with all the other treatment still in place, including the thinner center tube traps, the sound changes dramatically by just removing the corner tube traps.
People who have listened to my system have repeatedly praised presence and 3-D palpability of sound images, as if you could 'see' the performers standing in the hall, or as if you could reach out and touch them, as it were.
Yet now all the palpability of imaging is gone. Really gone. Images are larger, more diffuse and with no palpability at all. Greatly diminished presence. The sound is also somewhat more echo-y, and spatial information from the recording venue proper seems to come through less.
What some people had found particularly special about my system is gone. It still sounds great, but....
Just astonishing.
Those were my first impressions, on small-scale classical material.
But then I went to jazz and rock, where there is more bass, and rhythm.
Unbelievable. Also my excellent rhythm & timing is gone.
The tube traps affect the mid-bass big time. Now my mid-bass is diffuse and bloated. At first it seems that there's more mid-bass without the tube traps, but that initial impression quickly fades away. it's just more bloated and far less precise. The fast bass transients that Madfloyd admired so much with Green Day on my system are gone. And my rhythm is gone. Not just Green Day. I tried some jazz, AC/DC, Zappa, Elvis, you name it. Gone.
Just remarkable.
It is obvious that in many rooms, like in mine, chasing for great bass without acoustic room treatment is futile. You could spend $ 20 K on upgrading your amps to get a better grip on your speakers, or on upgrading the speakers themselves -- if your room is the main culprit of blurring the bass, it won't matter. Four corner tube traps for just $ 2.5 K total will do the trick instead. You could try digital room correction, but also that only will get you so far. Nothing beats actual physical elimination of detrimental room reflections. Digital room correction on top of that is fine, but it cannot be a substitute.
Fortunately I'll get my corner tube traps back in a few days.
Just astonishing.
Just remarkable.
