I am in the early stages of thinking about selling my home and moving. The house we are considering has a room that would be my HT/listening room. The existing dimensions (if I do nothing to change them) are 24'8" long by 16'10" wide by 96" high (YUCK).
I can do nothing with with the height (I refuse to lower it even if it would help). The length will be shortened as I need to build a "wall" to hang the screen and maybe make room to have my center channel behind the screen. The amount I shorten the room is somewhat flexible. The width can also be reduced but I would not want to reduce it much.
I have the SGTH Excel spread sheet but I'm looking for and other advice on how I might best determine the appropriate dimensions. This will be a dedicated space so whatever room acoustics are necessary will be utilized.
Utilizing the SGTH model and the dimensions as is will create serious resonance at approximately 68 and 70hz from the height/length combination (fails the Bonello dimension analysis test). I had another room with similar dimensions and it had a 15 db peak at about 65hz !!!!
I am open to any recommendations.
The other home we are considering has a room of approximately 19' x'27' x 8 feet, but that home has some other issues we would prefer not to have.
