Benefit of QUATs as an anti-static groove coating after cleaning/rise
Ceraunophile
2
64
37923
Although I'm in my mid 60s, I just caught the Vinyl audiophile bug--primarily in vintage classical. Although I am a Chemical as well as Electrical Engineer, my career has been in the product/process development of electrochemical glucose sensors for Diabetic patients; recently retiring from Medtronic as the VP of Global Operations. So, beyond a few first principles and only ~ month researching Vinyl and Vinyl cleaning methods, I am mostly ignorant of the subject matter. I was brave enough to engage Neil Antin (quite the Vinyl cleaning geru) and in my second reply to Neil's advice, I queried him on the benefits of QUATs as a thin NVR anti-stat coating step following clean/rinse. Neil indicated that the RCM thread was not the best place for a QUAT discussion, but being that I am new to forum engagement, please forgive me if I have initiated this thread in the wrong place. Let me provide a bit of background reference material that I have come across and then my query to the members so inclined to engage.
In the attached 1960 paper Anti-Static Phonograph Records, G. P. Humfeld, the cationic material Catanac SN is described as an antistatic agent and cationic surfactant (specifically, stearamidopropyldimethyl-l3-hydroxyethylammonium nitrate) manufactured by American Cyanamid Co. Note that Catanac SN has been discontinued due to its aquatic toxicity.
In the attached RCA patent, filed in 1974, 1498409551006799538-03960790 (storage.googleapis.com) for Vinyl record composition, Methylammonium methosulfate is listed as one of the ingredients which is a type of quaternary ammonium cation (QUAT) that the patent claims was added to the RCA Vinyl formulation for its antistatic properties.
I have stumbled across references to other cationic surfactants, including Quaternary Ammonium Salts that are suggested as beneficial in providing anti-static effects as well as even serving as a stylus lubricant. This suggests an intentional Non Volatilizing Residue (NVR) additive that will migrate from the bulk of the Vinyl polymer to provide a replenishable groove coating to enable the anti-static benefit. And yet, if an anionic surfactant (e.g. in Liquinox) residue remains in the groove, due to insufficient removal in rinsing, that anionic surfactant will cationic surfactant can form a sticky paste type residue; making rinsing off of the anionic surfactant quite critical.
Please share your thoughts on the antistatic benefit(s) of adding a Cationic surfactant coating to a cleaned record? If beneficial (I'm reticent to incorporate into my process) is something like Hepastat 256 (Reference attached MSDS) a good option; appreciating that other non-QUAT additives are in its formulation such as ethoxylated alcohol (CAS 68439-46-3), Sodium EDTA and Sodium metasilicate (Na₂SiO₃)? Other QAUT choices possibly being one of the common Quaternary Ammonium Salts such as alkyldimethylbenzylammonium chloride (ADBAC), benzalkonium chloride (BAC), benzyldimethylammonium chloride (BKC), or dialkyldimethylammonium chloride (DDAC) or one of the Quaternary Ammonium Salt Type Cationic Surfactants from Sanyo Chemical or possibly Deuteron's LE 292 (reference attached data sheet) which is in a IPA solution.
Here's the provocative question: If a cationic additive that is intentionally left as a hygroscopic (moisture adsorbing) groove coating to mitigate static charge is beneficial; appreciating that RCA intentionally formulated 0.6% Methylammonium methosulfate into their PVC/PVAc resin for its anti-static benefit, then are > 120 KHz Ultrasonic cleaning processes removing this intended coating from the groove surface for the purpose of removing that coating because it contains embedded undesirable particulate, but once removed, we would ideally replace that antistatic coating as a final post clean/rinse restoration step? Hmmm, things that make one go hmmm (Well, at least me)....
  • RCA Vinyl formulation patent--US3960790.pdf
  • Humfeld-AntiStaticPhonographRecords.pdf
  • Hepastat 256 MSDS.pdf
  • Deuteron-LE-200_LE-292-UK.pdf
  • Wow
Reactions: mtemur
Wait, Neil just replied with an awesome response provided unaltered below:
What RCA did was develop what is called an internal anti-static additive. In this case, they coated the pellets which are then heated/extruded into a puck that is heated/pressed into the record. In this case, the anti-static is now part of the vinyl; it alters the properties of the vinyl, and being part of the vinyl, it's durable so your concerns with the Degritter or any UT tank are unfounded.
Adding an external anti-static is entirely different. It applied as a coating, it's a residue. As far as any risk with Liquinox and its anionic surfactants, causing an adverse reaction with a cationic surfactant, first Liquinox rinses very easily, one of the reasons I recommend it. Secondly, the final clean step with only Tergitol which is only a nonionic surfactant, it compatible with any surfactant and part of the final clean step is ensure there is no prior chemical residue, so your concerns with Liquinox reacting with a cationic surfactant are unfounded.
I am going to assume that you read Section VIII in the back the chapter where I review the formula that uses Hepastat 256. You as a chemical engineer should be sensitive the rocks that formed when a meta-silicate dries and the difficulty in getting them back into any kind of solution.
If you want to try a QUAT, then a good product that some use is CONTROL III https://cpapx.com/products/control-...tm_term=cpapx&utm_content=CPAPX - Dynamic All (you can buy at many sites). It's a blend of only to QUATs in a 20% solution. Dilute and try between 200 to 500 ppm and try it in DIW/20%-IPA (or just add about 30-ppm Tergitol) so the rinse is a wetting solution because you want it to penetrate and fully wet the grooves to get the QUAT to adhere to the record surface as a pre-rinse to the final DIW Rinse or as the final rinse. Keep in mind, that any sponge/cloth you use to dry the record will become contaminated with the QUAT, and you will need to deal with that or just let the record dry with no wipe down at all. Beyond this you will just need to experiment with it a get the one that works for you. Do use the QUAT with the Degritter - you will likely damage the pump/filter system.
Please beyond what I have provided here, ask me no further questions on QUATs. It's your mission and your experiment, not mine. I am no longer retired, and I have no issues with helping people with what I wrote in the book, but that's as much as I have time for.
Take care & good luck,
Neil
Let me correct that sentence to read: "Do not use the QUAT with the Degritter - you will likely damage the pump/filter system." The basis is the Control III product literature https://cpapx.s3.amazonaws.com/control-iii-chemical-and-physical-properties.pdf that on the last page addresses Damage to Materials and metals corrosion. Also, a safety note: in its concentrated form as delivered, per the label https://cpapx.s3.amazonaws.com/control-iii-disinfectant-label.pdf Corrosive. Causes irreversible eye damage and skin burns. Wear goggles or face shield, protective clothing and rubber gloves when handling.
Otherwise, what I wrote above has some obvious grammatical errors. My apologies, I kind of hammered that out pretty quickly for one-persons view in a private exchange and did not take much time proofing for a general forum post viewable by many.
Take care,
Neil
I tried Hepastat 256 in my wash tank and found it raised the tank's TDS unacceptably high, as measured with a HM Digital 716160 COM-100 meter. That was sometime ago and I do not recall how much I used or by how much it increased TDS. I have no interest in adding substances to my records.
If there is a concern about static on vinyl other approaches are available.
The Milty Zerostat has been around for quite a while. Medium effectiveness.
Ronxs Lighter
Furutech DeStat III
CS Port Static Eliminator 1ME1
Nah, you're fine -- thanks for your contribution. Welcome.
