Can I replace the speaker with 3.5 mm audio jack?
hyuna
9
Hello, I am wondering if I can replace the speaker with 3.5 mm audio jack and input the audio to my laptops microphone in so I can record the sound using a software such as audacity. I don't know the input specifications and afraid that inputting amplified voltages over 5 volt would damage the microphone input port of my laptop. Thanks in advance for your reply.
I don't know if Iunderstand.
Please disregard if I am off point.
Are you talking about recording sound directly or an electronic signal? It is far easier to record the electronic signal.
Could you give us more details?
Hello, I am wondering if I can replace the speaker with 3.5 mm audio jack and input the audio to my laptops microphone snaptube vidmate in so I can record the sound using a software such as audacity. I don't know the input specifications and afraid that inputting amplified voltages over 5 volt would damage the microphone input port of my laptop. Thanks in advance for your reply.
do you want to modify it ?
