I would like to upgrade the power supply by-pass capacitors in my tube amp and have a question that maybe someone here can help me with. I am not an expert at this but I can solder and have changed out the caps on my DAC with great results so I would like to do the same with my amp. My question is this, the caps that are in the amp are 450v 470uf, I can not find capacitors from the major manufacturers at the 450v spec. I can find 400v and 600v, so would either of these work in my amp and if so what general differences can I expect going either a little higher or lower on the voltage of the cap. Thanks in advance guys.
