Confused about impedance matching DAC to Integrated
bRnzBzh
2
1
68
68
This has probably already been discussed at some point but I'd appreciate it if someone could either explain this to me in simple terms or point me towards an easily-understood explanation. I don't have an engineering background nor am I good at math.
According to Hegel, my H390's "power is delivered through a low 0.014-0.048ohm source impedance". I've read elsewhere that the amp's input impedance should be at least 10X the DAC's output impedance and preferably more. Does Hegel's description of the H390's input impedance as "low" suggest it will be difficult to find DAC that will be well matched?
Specific Example:
I'm researching DACs and the Ferrum Wandla GoldenSound Edition looks interesting. It's output impedance is reputedly 22 ohms unbalanced. It also has "a hardware voltage divider circuit that allows the user to adjust the output voltage from just under 10 Vrms to just under 4 Vrms. This adjustment allows the WANDLA to be compatible with a wider range of amplifiers".
Would the Wandla GoldenSound Edition be a good match for the H390?
Hmm… I’m reading the Hi-Fi News review of the H390. It seems that the low 0.014-0.048ohm is actually the output impedance to the speakers. I think the input impedance of the preamp section of the H390 is actually 951ohm.
Now if you think about it, most preamp/amp manufacturers are going to make sure their amps are compatible with their own DAC or CD players. Hegel Viking has output impedance of 22ohms according to Hi-Fi News’ measurement. And it should be compatible with their H390.
So I think you’ll be fine from an impedance matching perspective using Wandla GoldenSound Edition with the H390. Remember to make sure your DAC output voltage doesn’t clip the input of the H390 too.
OK. That's the same article I read. Clearly, I misunderstood. I appreciate your taking the time to explain and wish you a Happy Thanksgiving!
Reactions: ecwl
