drive Dynaudio Focus 380 suggestion
pigangry
3
I have a pair of Dynaudio Focus 380 and now is looking for the amp. I prefer integration amp because it is more easy for me to setup the audio system.
here is the list someone recommended to me so far, I'd like to hear any advice from you all. Thanks in advance!
FM NuVista 800
Simaudio 700i
Pass Labs Int-60
ARC + Pass
Devialet 400
I heard NuVista 800 driving Focus 380 in the shop. It sounds good but the dramatic seems not enough .
And I am also not sure Simaudio 700 is enough to drive 380.
Maybe add the Plinius Hiato to the list of candidates?
Eric,
You should also consider the Ayre AX-5 Twenty. Ayre is superb to my ear and will be awesome on the 380's. I am not sure where you are located but with a bit of a discount, it could be your destination integrated amp.
I'd also add the PS Audio BHK 250 and BHK preamp to the list.
Joe,
thanks! I am going through the Ayre Ax-5 spec. It is quite new to me seems very excellent!
