My big tube amp stopped working almost two months ago, and I finally decided today to get it off the shelf and send off to get repaired (still here at the moment). Earlier in the day I walked over to my local hi-end shop and looked at the used section, and this little but heavy Dynaco amp whispered to me.
I did a little research, not the most dependable thing, many have had poor repairs done as a result. However, what I paid today ($115) is most likely what I'll get for it a few years down the line if I don't push it too hard.
Here is my temporary amp, the filler for until the tube amp gets fixed.
http://s184.photobucket.com/albums/x295/kach22i/Stereo/
For a couple of bucks the stereo guy sold me some brass jumpers out of his drawer so I could get my larger modern RCA's and speaker lines hooked up. It's all sort of wobbly, but works.
Sound?
The first couple of minutes were flat, very thin, dry, screechy and bright and tin-like.
I've had it playing for 15 minutes or so now, sound stage has much greater depth, and it is a very quick amp. It still has somewhat of a lisp and sizzle to it right now.
Keep in mind I have super tweeters on my Martin Logan Aerius speakers to give a tubes a little more top end, I may have to..................hold on there folks let me check something! Augh!!!
Sure enough, I had the super tweeter leads reversed, they were in phase in lieu of out of phase as they should be when facing backwards.
CORRECTION: Alright, the sizzle and lisp is within reason now. In fact it's pretty darn good for solid state. Light, quick with a Linn-like toe tapping tempo.
I'm going to have to compare the 60 watt Dynaco to my 100 watt Rotel (now serving HT duty). My guess is that the Rotel will be a little more rich, the Dynaco a little brighter and quicker, but that is just a guess.
The high hats and cymbals are really open and clear on the Dynaco, a great sense of space is starting to open up.
Stay tunned, I'll report more when I've had more listening time under my belt.
A good link on this amp:
http://www.davidreaton.com/Dynaco_120.htm
Sound?
GENERAL
This page contains everything I know about the Dynaco Stereo 120 power amplifier. This was Dyna’s first transistor amplifier, introduced in 1966 and sold for more than 10 years. The design was minimalist – only 6 transistors were used per channel. The unit operated in a class A-B mode (like many tube amplifiers) and used a whopping big output capacitor to decouple the DC offset of the amp (like tube amps use an output transformer).
