I read Fidelizer comments in forums and found most people believing it's just shutting down services with some process tweaks that could be done with batch file. I'd like to make proper explanation here to tell you what Fidelizer does beyond that in details.
This is what Fidelizer does writen in my website.
-Optimize audio thread, I/O priorities, clock rate in resource scheduler
-Optimize network utilization for low latency streaming media
-Optimize process thread priorities and system clock resolution
-Optimize processor core assignment for multi-core CPU
-Launch audiophile player with Fidelizer optimizations
-Stop most system services leaving only audio-related ones
Read more at http://www.windowsxlive.net/fidelizer/
While this may not be clear enough, I'd like to rephrase again.
Fidelizer's core optimizations does 3 things you should consider that no other software does or advertised those features.
a) MMCSS optimizations - You may see a few of MMCSS optimizations online but Fidelizer doesn't do it like others you see. The first thing is it doesn't permanently change MMCSS optimizations. The second is my MMCSS optimizations is done from hard work and long research of digitial audio in 'highend systems'. I did what it was best for real highend systems with audition from respected digital highend shops here. It also does balancing between system/audio/network and let you configure for best music listening experience for streaming media as well.
b) Kernel timer resolution optimization - This was introduced way back in a few places. I think it's firstly introduced in digital audio by Peter from XXHighend. I personal discovered this from DPC Latency checker software. I used to have stuttering audio for low latency playback but after running DPC Latency checker, it stopped stuttering. So I look further and found this software changed timer resolution from 15.6ms to 1ms fixing this stuttering issue. Fidelizer also does this and will set it to lowest possible (0.5ms).
c) Audio thread priority optimization - This is the only and unique feature where I'm confident that no one else have done that before and you can never do it yourself from system tweaks or batch script. It will optimize audio thread priority to high priority improving audio performance significantly 'by native API'. It's NT6 API feature that allows Windows to adjust audio thread priority directly and Fidelizer does that 'FOR FREE'.
This are the solely reason why you should consider trying Fidelizer and don't just treat this as some services/process tweaks software. And I'd like to add that not all software does the same optimizations, Fidelizer/XXHighend/AudiophileOptimizer/some batch scripts won't assign the same core affinity and lowering/increasing process priority all the same too.
Even if you already does all that thinking it's your optimal optimization, Fidelizer can still further improve it with its core optimizations as I mentioned above. Core optimizations made Fidelizer original and there's no alternatives right now. I hope you'll enjoy good music with Fidelizer and happy new year 2015.
Cheers,
Windows X
Cheers,
Windows X
