Hires on a portable
Vincent Kars
WBF Technical Expert: Computer Audio
Jul 1, 2010
860
2
1,578
Iriver AK100 is a portable media player supporting lossless formats like WAV and FLAC up to 24 bits / 192 kHz
Price: € 799,-
MODEL AK100 Specifications:
Display 2.4” QVGA(320X240) IPS Touch Screen
Audio Format WAV, FLAC, WMA, MP3, OGG, APE
Sample rate FLAC, WAV: 8KHz ~ 192KHz(8/16/24bits per sample)
Output Level 1.5VRMS(No Load)
Audio Frequency Response 10Hz to 20KHz +/-0.02dB (24bit 48Khz, No Load)
Signal to Noise Ratio > 110dB (1KHz 0dB, 24bit 48Khz, No Load)
Crosstalk < -120dB (1KHz 0dB, 24bit 48Khz, No Load)
THD+N < 0.0009% (1KHz 0dB, 24bit 48Khz, No Load)
IMD SMPTE < 0.003% (24bit 48Khz, No Load)
Clock Source Clock Jitter 50ps
Storage Flash Memory 32GB [NAND] SD Slot MICRO SD [Max 32GB] slot x 2
DAC Wolfson WM8740 24Bit DAC
Decoding Support up to 24Bit/192kHz Bit to Bit Decoding
Interface USB 2.0, OPTICAL IN/OUT, Headphone Out
Battery Capacity 2,000mAh 3.7V Li-Polymer
Battery Playback Time Max 16hours
Charging time About 5 Hours
Size 59.2[H] X 79 [W] X 14.4 [D]
Weight 122g
Support Firmware upgrade
OS Windows 2000/XP
