K kaeksen Well-Known Member Jun 11, 2016 25 1 81 Norway Jul 4, 2016 #1 My burmester 082 doesnt have a date/year on it, how can i find out?
audio.bill Well-Known Member May 27, 2013 576 111 955 Chicago suburbs Jul 4, 2016 #2 You'd probably have to contact the manufacturer with the serial number, then they should be able to tell you when it was built.
K kaeksen Well-Known Member Jun 11, 2016 25 1 81 Norway Jul 4, 2016 #3 Yeah, youre right,thx Ok, i got in touch with them now, and soon waiting on email from them about this. Im excited, and eager waiting this info from burmester, feels better to know the integrated amps age. Last edited: Jul 5, 2016
K kaeksen Well-Known Member Jun 11, 2016 25 1 81 Norway Jul 21, 2016 #4 audio.bill said: You'd probably have to contact the manufacturer with the serial number, then they should be able to tell you when it was built. Click to expand... Ok found out the amp was made in march 2011, so 5 years old and i bought it for half the original price. Im pleased.
